Blackwrx02 Posted April 29, 2010 Share Posted April 29, 2010 Our 05 LGT has a squeek coming from under the hood. Sounds like a pully or something maybe? Friend said his 02 WRX did the same thing and he believed it to be one of the motor mounts. Tried a search, but didn't come up with much. Anyone have this issue before and found a cure? Its not super loud, but can be heard outside the car more-so than inside. Only really notice it at idle and low speeds. (i.e. leaving the driveway) Link to comment Share on other sites More sharing options...
Pyrojones Posted April 29, 2010 Share Posted April 29, 2010 I had a start up squeak so when I took mine in to get the heated seats fixed I had them take a look. Ended up that the start up squeak was a bad timing pulley. Now almost 2 weeks later im getting my car back, but thanks to purchasing an extended warranty (that I used to look at as a scam) I have no out of pocket expense and a new timing belt b/c the pulley was causing unnatural ware on the belt. Something you may wanna look into. Link to comment Share on other sites More sharing options...
SubieSteve Posted April 30, 2010 Share Posted April 30, 2010 I had a tensioner pulley go on me once. Started as a squeak but got much worse in a short period of time. Ended up breaking off and doing some damage under the hood. All warrantied though. You can shoot the pulleys with a little silicone - but just don't hit the belt!! It will get you by until it needs to be replaced. Of course the best thing to do is replace it now, but I know for some people it's not always possible. Link to comment Share on other sites More sharing options...
