filly peeno Posted April 27, 2010 Share Posted April 27, 2010 So I turned off the drl on my 07 by cutting the blue wire with black stripe on the white connector. Now my fogs aren't coming on when I turn the headlights on. Did this happen to anyone else? Link to comment Share on other sites More sharing options...
mr.hicksta Posted May 8, 2010 Share Posted May 8, 2010 Yup....same thing happened to me. Link to comment Share on other sites More sharing options...
LegGT24 Posted May 11, 2010 Share Posted May 11, 2010 Check the harness itself. It may not be plugged in all the way which would be the cause of your problem. Same thing happened to me when I disabled DRL. Everything should work fine. Link to comment Share on other sites More sharing options...
tsunami Posted May 11, 2010 Share Posted May 11, 2010 ^+1 fogs work for me too and I cut that same wire. Although fogs are pretty much worthless with HID's Link to comment Share on other sites More sharing options...
filly peeno Posted May 13, 2010 Author Share Posted May 13, 2010 took it out and plugged it back in and still doesnt work. yeah they are pretty worthless with hids just wondering why they dont work though because they should. Link to comment Share on other sites More sharing options...
EquinnoxX Posted May 14, 2010 Share Posted May 14, 2010 I did the same mod and mine still work. Are you sure the brights aren't on? Stupid I know but figured it may be a simple fix. I don't think the fogs will go on when the brights are on. Link to comment Share on other sites More sharing options...
