rocketman Posted April 13, 2005 Share Posted April 13, 2005 Has anyone else noticed their outside temp display being SERIOUSLY out of whack? Like, not by 3 degrees Fahrenheit, but 10 or 15? Mine said it was 92 degrees a couple of days ago. I know it's Atlanta, and I was parked in the sun, but it's April fercrissake. Ain't no such temperature down here. :-) Powered by Mac OS X Server Link to comment Share on other sites More sharing options...
Deer Killer Posted April 13, 2005 Share Posted April 13, 2005 How hot do you think your car gets sitting in the sun? Link to comment Share on other sites More sharing options...
dougc Posted April 13, 2005 Share Posted April 13, 2005 nope, not have a problem w/ the temp display. However, the MPG one, when I am driving keeps changing every 2 secs...it will from let's say 26mpg then 54, then 99, and so on. Does anyone's else do this? Link to comment Share on other sites More sharing options...
stiffarmleft Posted April 13, 2005 Share Posted April 13, 2005 nope, not have a problem w/ the temp display. However, the MPG one, when I am driving keeps changing every 2 secs...it will from let's say 26mpg then 54, then 99, and so on. Does anyone's else do this? It's supposed to do that , it's instantaneous mileage. Link to comment Share on other sites More sharing options...
dougc Posted April 13, 2005 Share Posted April 13, 2005 oh ok, just seemed odd when it jumped up to 99.9 Link to comment Share on other sites More sharing options...
eamiller Posted April 13, 2005 Share Posted April 13, 2005 Most temperature sensors are mounted in the front grill somewhere, in front of the radiator.. When you stop your car, they heatsoak quite rapidly. This also means that the sampling rate is tied to vehicle speed, slower sampling when moving slowly and faster when going faster. This tends to make the "apparent" accuracy very good. However, that initial sample at power-on will be high if the sensor has been heatsoaked. In general, after a few minutes of sustained speed driving, it should calm down to a more accurate reading. Link to comment Share on other sites More sharing options...
rocketman Posted April 13, 2005 Author Share Posted April 13, 2005 > heatsoaked That explanation makes sense. I'll try to monitor and see if it looks more reasonable after speeding for a while! :-) Thanks! Powered by Mac OS X Server Link to comment Share on other sites More sharing options...
John M Posted April 14, 2005 Share Posted April 14, 2005 Finally there's another member in GA! And yes, it's heatsoak. Link to comment Share on other sites More sharing options...
