illt3ck Posted April 13, 2005 Share Posted April 13, 2005 and if they do, are they an upgrade to our existing brake system? http://img.photobucket.com/albums/v474/Jay_bee_UK/Picture018.jpg Link to comment Share on other sites More sharing options...
nKoan Posted April 13, 2005 Share Posted April 13, 2005 You could probably make them fit. It wouldn't be easy (not too tough I bet) and I don't know how much of an advantage you'd get from having them. The rotors are a smaller size on these brakes (meant to fit under some 16" wheels), but they are a four-piston front/two piston rear design (as opposed to the 2 piston front/1 piston rear that come stock) that we have. I believe you would actually have slightly less stopping power (just an assumption) but you would be more resistant to brake fade and pad wear would be a little more even. Fronts could theoretically bolt up with the proper mounting brackets. And honestly, I don't even know if the rears would fit at all and how not having the full setup would affect your brake bias/balance. Personally, I'd say don't bother. Get a different big brake kit, one specifically suited for the Legacy, rather then getting these. Link to comment Share on other sites More sharing options...
Xenonk Posted April 14, 2005 Share Posted April 14, 2005 If you are talking about Subaru 4 pot fronts and 2 pot rears, then yes, they can fit, but you need the caliper bracket that fits along with the rotors and you need new wheels as the stock wheels wont fit over the front 4-pot brakes. Also, you might need a longer brake line in the rear as the banjo bolt on the caliper is bolted in a different location where it might be too far for the brake line to connect. Keefe Keefe Link to comment Share on other sites More sharing options...
ICTM AG Posted April 15, 2005 Share Posted April 15, 2005 i would not spend $1 for those brakes they are too bad! i had those on my impreza and i had all the time problems with fading! okay i drive like crazy up and down the alps but if you buy brakes don't spend on crap like that! my ex impreza's Link to comment Share on other sites More sharing options...
Drift Monkey Posted April 15, 2005 Share Posted April 15, 2005 Those are tiny rotors! Link to comment Share on other sites More sharing options...
Xenonk Posted April 15, 2005 Share Posted April 15, 2005 i would not spend $1 for those brakes they are too bad! i had those on my impreza and i had all the time problems with fading! okay i drive like crazy up and down the alps but if you buy brakes don't spend on crap like that! my ex impreza's You overheated your brake pads and brake fluid.. Keefe Keefe Link to comment Share on other sites More sharing options...
ICTM AG Posted April 15, 2005 Share Posted April 15, 2005 yes including the brakedisk's they got a blue touch:D but afterwards i changed the disk's and i took sloted one's and i had the ferrodo ds 2500 pad's with new brakefluid but it was only a little bit better! and don't forget my impreza was only 2900lb so i would say those brakes are to small for the legacy but this is my opinion i'm open for diffrent coments! i would recomend something like the stoptech bigbrakekit if you realy wana improve the brakesystem! Link to comment Share on other sites More sharing options...
Gator GT Posted July 24, 2005 Share Posted July 24, 2005 If you are talking about Subaru 4 pot fronts and 2 pot rears, then yes, they can fit, but you need the caliper bracket that fits along with the rotors and you need new wheels as the stock wheels wont fit over the front 4-pot brakes. Also, you might need a longer brake line in the rear as the banjo bolt on the caliper is bolted in a different location where it might be too far for the brake line to connect. Keefe Yes stock 2005 Legacy GT rims (17x7 +55mm) do fit over FHI 4 pots. Tried it myself. GGT "If we are to guard against ignorance and remain free, it is the responsibility of every American to be informed." - T. Jefferson Link to comment Share on other sites More sharing options...
