Kreamer67 Posted April 19, 2010 Share Posted April 19, 2010 2006 LGT , lately its been idling rough, almost as though its got a misfire, it also sometimes will hesitate under acceleration. When the hesitation gets bad the car stops boosting 11-13psi and will only boost 6-8psi and runs like dirt. The problem is intermittent and did it with the cobb accessport and with it completelty uninstalled. The car is also bone stock save for a removed snorkel/ intake resonator. Any ideas? Link to comment Share on other sites More sharing options...
TSiWRX Posted April 20, 2010 Share Posted April 20, 2010 Check the "T" vac lines, it's under the TMIC. My bet is that one of them popped off the T. If you hadn't done so, Zip-Tie them onto the T. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Zac88 Posted May 2, 2010 Share Posted May 2, 2010 my car is having a similar issue, I looked but did not see any T line. Can you show me a picture? Link to comment Share on other sites More sharing options...
TSiWRX Posted May 3, 2010 Share Posted May 3, 2010 http://legacygt.com/forums/showthread.php/ziptie-not-enough-t-connector-vac-lines-44023.html?t=44023&highlight=vac+lines ^ <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
blinger Posted May 24, 2010 Share Posted May 24, 2010 I have a somewhat rough idle and hesitation around 2k rpm as well. My T connector did pop off which threw a CEL code P0171. Had that fixed, but the rough idle and hesitation is still there. Could this be a possible spark plug issue? What are the 05 Legacy GT plugs gapped at? Link to comment Share on other sites More sharing options...
Kreamer67 Posted May 25, 2010 Author Share Posted May 25, 2010 update. it was a loss of compression in cylinder 4. stay tuned for forged bottom end build. by the way if anyone knows the cause of the discoloration in this picture feel free to chime in http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs503.ash1/29773_398527701436_640116436_4797080_6263407_n.jpg Link to comment Share on other sites More sharing options...
boymk123 Posted May 26, 2010 Share Posted May 26, 2010 2006 LGT , lately its been idling rough, almost as though its got a misfire, it also sometimes will hesitate under acceleration. When the hesitation gets bad the car stops boosting 11-13psi and will only boost 6-8psi and runs like dirt. The problem is intermittent and did it with the cobb accessport and with it completelty uninstalled. The car is also bone stock save for a removed snorkel/ intake resonator. Any ideas? my car has the same problem after I put some cheap 93 gasoline into it. (out of gas in the middle of nowhere, had no choice). Water damaged the fuel pumps, and now cylinder 1,3,4 are all misfired, need to replace 3 injectors.... good thing, I got my insurance cover it under the comprehensive but need to pay 500 bucks deductible. Link to comment Share on other sites More sharing options...
