jaxx4k Posted April 18, 2010 Share Posted April 18, 2010 Im bout to buy a car tomorrow with 106k on a 2005 LGT ,as long as it checks out no leaks or any problems. car is from a dealer which they don't have any records of maintenance. where should i start?? timing belts,water pump? any recommended upgrade/maintenance do you have? thanks for any info & 2 cent you have.... Link to comment Share on other sites More sharing options...
MadMontie1 Posted April 19, 2010 Share Posted April 19, 2010 this car should have had everything done to it already including the timing belt. tranny, coolant, and diff fluids should have been twice. also, given the mileage and the history of the 05-06s, i would not be surprised if this turbo has already been replaced due to failure. if you cant confirm whether or not its the original turbo or if the timing belt has been replaced, i would think twice. seeing as though someone turned it in at 106k, i would not be surprised if the timing belt was not done since it's suggested at 105k Link to comment Share on other sites More sharing options...
jaxx4k Posted April 19, 2010 Author Share Posted April 19, 2010 ok... doing the belt/pump is not a big problems.. also, would i reply the bearings thats in the area of the belt?? cause i see the sell a belt kit that comes with those bearings... Link to comment Share on other sites More sharing options...
