doctorbrody Posted April 16, 2010 Share Posted April 16, 2010 I just installed Polk DB6501 components in the front and Polk DB650 coax in the back, and when I play something with very deep, droning bass, I get a loud buzz. I can't tell if it's a vibration within the door panel, or a sound that's coming through the woofers. Any thoughts on what's happening? My head unit is from an 06 Spec B with the Jazzy Aux-in, and I have the factory subwoofer. Link to comment Share on other sites More sharing options...
ibhknl Posted April 17, 2010 Share Posted April 17, 2010 1. Is the woofer (cone) contacting anything? 2. Does it come from all speakers or just one? Use the fader, fade L to R and F to B and isolate if possible. 3. You could be, but not too likely, overpowering the speakers.... yeah, maybe... Link to comment Share on other sites More sharing options...
peteyjr Posted April 20, 2010 Share Posted April 20, 2010 Probably some door resonance . Use the above method to track down the offending speaker. Consider either 1) changing the amount of bass to your speaker or 2) changing the cutoff highpass frequency 80-100htz etc and 3) sound deadening or should I say dampening the doors (highly recommended) Link to comment Share on other sites More sharing options...
