kopke Posted April 15, 2010 Share Posted April 15, 2010 EDIT: I the search engine did not come up whit any good answers Greatings. It's time to give MY '06 some love. It's a 2.0 lux version whit a auto climate. Gx-201 HU. Sedan Let's face it. The Audio system we are given is not the best on the market. I'm going to improve mine. I have not yet pikt the sub, speakers or amp but that's not important. The wires on the other hand. That's wear I have a problem. I got my self a converter. I simply don't have the $$$ for a din. I'll have to live whit the ******* EQ the HU has. From what I have bin reading getting to the spacer wires in the back doors is not to hard. But I'm not feeling like braking my interior. So how do I get to the dam wires? simple pop-out or are there some hidden clips I need to know off? http://img580.imageshack.us/img580/6936/p4150038.jpg Next is the ACC. I'll be getting that from the center box in the car where I have a 12v plug. But I have to get the dam box out of there. How? http://img683.imageshack.us/img683/2046/p4150039.jpg And then it's the power wire and that's wear I'm completely lost. I'm not going to drill any holes in my car that's for sure. So how do I get a wire from the battery in the front to the trunk:confused: I know it's hardly necessary but I'll pose some pics in 2 hours. I will do my best to make a GRATE DIY after I'm done. If my dam camera will make it. Link to comment Share on other sites More sharing options...
ibhknl Posted April 17, 2010 Share Posted April 17, 2010 Dude, your killing me. Spell check and proof read your post. Then (maybe) someone will answer you. Link to comment Share on other sites More sharing options...
kopke Posted April 17, 2010 Author Share Posted April 17, 2010 I'm sorry. I was in a hurry and I AM dyslexic. But Done and Done. BTW. I have bin using the search engine. Did not find anything. Link to comment Share on other sites More sharing options...
clarkwgriswold Posted April 17, 2010 Share Posted April 17, 2010 Dude, your killing me. Spell check and proof read your post. Then (maybe) someone will answer you.[/QUO I bet you feel like a dick! Link to comment Share on other sites More sharing options...
clark687 Posted April 18, 2010 Share Posted April 18, 2010 I just bought the Pioneer avh4200 and 2 12's orion, best investment ever! Link to comment Share on other sites More sharing options...
kopke Posted April 20, 2010 Author Share Posted April 20, 2010 Seriously. There has to be someone hear that know how to get a power wire from the battery to the hood Link to comment Share on other sites More sharing options...
MaStaMooN Posted April 20, 2010 Share Posted April 20, 2010 Power wire can be pulled through a grommet in a few places on the firewall. I used the unused portion found in the driver side kick panel. All you need to do is pull the fender liner from the driver side wheel well to see it. Make an X with an exacto knife and start pushing the wire through.. you should be able to retrieve it very easy inside the cabin at that point. Then you just pull up the carpet along the doors by removing the side sills and lay the wire through. Its pretty easy once you get going.. just take it one step at a time. I taped the same spot for my remote wire (cig lighter in arm rest).. think you gotta pull the center console to get to it though.. cant remember. Good luck! Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
biz77 Posted April 20, 2010 Share Posted April 20, 2010 Seriously. There has to be someone hear that know how to get a power wire from the battery to the hood Why do you want a power wire running to your hood? Here, check out my install log. Maybe there is something useful there: http://www.diymobileaudio.com/forum/diyma-build-logs/28380-rsvchads-2006-legacy-gt.html Link to comment Share on other sites More sharing options...
kopke Posted April 22, 2010 Author Share Posted April 22, 2010 Why do you want a power wire running to your hood? Here, check out my install log. Maybe there is something useful there: http://www.diymobileaudio.com/forum/diyma-build-logs/28380-rsvchads-2006-legacy-gt.html Sorry meant trunk. I read your treed and it was mind blowing. After seeing your level of detail and craftsmanship I hardly have the guts to start working on mine. A few question tho layer of RAAMmat for the trunk What fore? Opening up the trunk to let more bass in http://img.photobucket.com/albums/v375/biz77/Legacy%20GT%20audio/Rear%20deck%20vent/IMG_0024.jpg Is it making a dirfrines in sound? Removing the back seat? How? I did not see any screws securing the seat. Finaly. The Interior. is it hard to get those wires along side the car? Anything I have to be aware of? Thank's agen fore a grate post. Link to comment Share on other sites More sharing options...
biz77 Posted April 22, 2010 Share Posted April 22, 2010 RAAMmat is to keep noise out of interior. If I were to do it again I would use the mat very sparingly and use more of the cloed-cell foam to keep road noise out. Difference in sound? Yes, it does make it a bit louder. Lift up at the front of the bottom cushion. You need to be forceful. You'll then see the bolts holding the seat back in place. Undo bolts and lift seat back straight up and out. Be very careful with the interior trim peices. The front ones come off easy, the back ones require patience. Use an interior removal tool to get under the panels and pop the clips that hold them in place. Link to comment Share on other sites More sharing options...
