LegacyFuture Posted April 14, 2010 Share Posted April 14, 2010 Driving home in S# around 60mph. I have automatic transmission Legacy GT 08. Suddenly the transmission does the hardest gear change ever of my life time. It hit so hard that I thought I just ran into a brickwall highway speeds. I couldn't concentrate on the road after the hit for few seconds, wondering if my car is okay and what's going on. It did it before lightly, which I just ignored. And it was useless telling the dealer, since they won't be able to duplicate these type of things. I think there must have been some kind of massive damage to my transmission, no way these parts can obtain that much force without damage... I have maintenance very soon, I will mention it. All I can say I had an accident before @ 30mph in another car... it was nothing compared to this.. the accident felt light compared to what I had yesterday. Link to comment Share on other sites More sharing options...
joeblow Posted April 14, 2010 Share Posted April 14, 2010 Where was the temp gauge at? My car shifts hard at higher RPMs for the first 5-10 minutes of driving depending on the outside temperature. The shift from 2nd to 3rd is always the worst. It takes a few minutes to warm the fluids up to operating temperature, so if the trans fluid was still cold, that could be your reason. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
LegacyFuture Posted April 14, 2010 Author Share Posted April 14, 2010 Where was the temp gauge at? My car shifts hard at higher RPMs for the first 5-10 minutes of driving depending on the outside temperature. The shift from 2nd to 3rd is always the worst. It takes a few minutes to warm the fluids up to operating temperature, so if the trans fluid was still cold, that could be your reason. I was only driving about 3 mins when it happened... Link to comment Share on other sites More sharing options...
RJS5689 Posted April 14, 2010 Share Posted April 14, 2010 I was only driving about 3 mins when it happened... You also said you were doing 60, so I assume this was a 4-5 shift? Link to comment Share on other sites More sharing options...
CTATV Posted April 14, 2010 Share Posted April 14, 2010 i would assume they are talking about a downshift considering the "brick wall/truck" stopping comment Link to comment Share on other sites More sharing options...
LegacyFuture Posted April 14, 2010 Author Share Posted April 14, 2010 I believe it was down shifting... Link to comment Share on other sites More sharing options...
rockle3 Posted April 14, 2010 Share Posted April 14, 2010 I think the RPM is more important than the speed. You honestly shouldn't spool your turbo before all the fluids are warmed up. Link to comment Share on other sites More sharing options...
LegacyFuture Posted April 14, 2010 Author Share Posted April 14, 2010 I think the RPM is more important than the speed. You honestly shouldn't spool your turbo before all the fluids are warmed up. the car won't let you go into S# until its warmed up... I was in S# Link to comment Share on other sites More sharing options...
joeblow Posted April 14, 2010 Share Posted April 14, 2010 It won't let you into s# until the oil reaches a certain temperature, but that's not an indication of transmission temperature. You might want to check your ATF level. If its low, the tranny will shift harder and can be damaged. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
airborne200208 Posted April 14, 2010 Share Posted April 14, 2010 I have that problem in the mornings too. I just start my car a few minuted before I'm ready to leave now and all is fine. <-----HONDA SERIAL KILLER-----> RIP JHMEH6160RS006479 RIP 1HGCD5650VA021631 RIP JHMGD38688S015633 Link to comment Share on other sites More sharing options...
jmorris6689 Posted April 14, 2010 Share Posted April 14, 2010 did the car come to a stop? and are there any check engine lights? were you driving the vehicle hard? and were you shifting the gears with the paddles or was the vehicle shifting it self? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted April 14, 2010 Share Posted April 14, 2010 That sounds like fuel cut. Link to comment Share on other sites More sharing options...
LegacyFuture Posted April 14, 2010 Author Share Posted April 14, 2010 did the car come to a stop? and are there any check engine lights? were you driving the vehicle hard? and were you shifting the gears with the paddles or was the vehicle shifting it self? it slowed down ... wasn't driving the vehicle hard... it was D no paddles Link to comment Share on other sites More sharing options...
I 5EAT Turkey Clubs Posted April 14, 2010 Share Posted April 14, 2010 It auto-downshifted on you even though you were accelerating? Link to comment Share on other sites More sharing options...
LegacyFuture Posted April 15, 2010 Author Share Posted April 15, 2010 It auto-downshifted on you even though you were accelerating? in D the transmission does whatever it feels like. Link to comment Share on other sites More sharing options...
dmanaenk Posted April 15, 2010 Share Posted April 15, 2010 Brick wall? Seriously? The most deceleration you can experience while at speed is capped above by tire traction. So the most you can get - is as if you were threshold braking, which is nothing compared to hitting anything solid. Its just that you got it unexpectedly.... 666 Link to comment Share on other sites More sharing options...
kramm Posted April 15, 2010 Share Posted April 15, 2010 It auto-downshifted on you even though you were accelerating? I'm pretty sure that's what a 5eat does. If you floor it in S# the car definitely downshifts to give you that quicker acceleration. Link to comment Share on other sites More sharing options...
joeblow Posted April 15, 2010 Share Posted April 15, 2010 ^ makes sense. And if the ATF wasn't warmed up, it could have caused that hard downshift to drop a gear for acceleration. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
I 5EAT Turkey Clubs Posted April 15, 2010 Share Posted April 15, 2010 I don't have the S# option. My '05 does not do that...although I never even use the regular sport mode on my EAT... if I'm doing some spirited driving I am in manual mode anyways so I suppose I may have just never noticed. But it all seems to add up. OP- check your ATF levels. Note the color of the fluid as well to try and figure out how dirty it is and whether you need to flush it or not. Link to comment Share on other sites More sharing options...
captainhook Posted April 15, 2010 Share Posted April 15, 2010 That sounds like fuel cut. My thoughts exactly. Definitely not a pleasant experience. Link to comment Share on other sites More sharing options...
Verwilderd Posted April 15, 2010 Share Posted April 15, 2010 ^^^+2 Fuel cut will feel like you hit a brick wall and could have been caused by a number of factors including real hard acceleration combined with temp changes or even low fuel.... I would continue to drive and see if it does it again. If it does, then I would start looking into to things, but what you are describing sounds like fuel cut. If it were the tranny, you'd probably hear some bad noises when it does this. How hard were you accelerating? What exactly were you doing? Can you give a more detailed description of the situation? Link to comment Share on other sites More sharing options...
LegacyFuture Posted April 15, 2010 Author Share Posted April 15, 2010 ^^^+2 Fuel cut will feel like you hit a brick wall and could have been caused by a number of factors including real hard acceleration combined with temp changes or even low fuel.... I would continue to drive and see if it does it again. If it does, then I would start looking into to things, but what you are describing sounds like fuel cut. If it were the tranny, you'd probably hear some bad noises when it does this. How hard were you accelerating? What exactly were you doing? Can you give a more detailed description of the situation? I wasn't accelerating hard at the time or even at all, if its fuel cut wouldn't it be just instant loss of power? Link to comment Share on other sites More sharing options...
RJS5689 Posted April 15, 2010 Share Posted April 15, 2010 I wasn't accelerating hard at the time or even at all, if its fuel cut wouldn't it be just instant loss of power? So it just randomly downshifted with you driving under constant throttle? Link to comment Share on other sites More sharing options...
LegacyFuture Posted April 15, 2010 Author Share Posted April 15, 2010 So it just randomly downshifted with you driving under constant throttle? you drive a spec b, obviously you don't have to deal with these problems. All I know,sometimes it shifts at the wrong time. Link to comment Share on other sites More sharing options...
dmanaenk Posted April 15, 2010 Share Posted April 15, 2010 you drive a spec b, obviously you don't have to deal with these problems. Unless he misses a shift.... 666 Link to comment Share on other sites More sharing options...
