Legacy_GT_Pilot Posted April 12, 2010 Share Posted April 12, 2010 Last year I installed Rallitek Springs on the stock suspension. I love the ride quality and the slight drop in height I acheived. But now I have uneven wear on my tires as the camber is off - the inside of all 4 tires are worn more than the outside. Can I do anything with the stock suspension to alleviate this? Alignment maybe? Other thoughts? Link to comment Share on other sites More sharing options...
CwhillVT Posted April 12, 2010 Share Posted April 12, 2010 Dumb question but did you get it aligned post install of the springs? Link to comment Share on other sites More sharing options...
REDNECK_GT Posted April 12, 2010 Share Posted April 12, 2010 Adjust camber.... That is the answer Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted April 12, 2010 Author Share Posted April 12, 2010 Are you able to adjust the camber with the stock suspension though? I didn't know if there was any adjustability to the stockers. Adjust camber.... That is the answer Link to comment Share on other sites More sharing options...
captainhook Posted April 13, 2010 Share Posted April 13, 2010 Are you able to adjust the camber with the stock suspension though? I didn't know if there was any adjustability to the stockers. Front end adjustable camber with stock suspension: Yes Rear end adjustable camber with stock suspension: No Link to comment Share on other sites More sharing options...
djkxgo0k Posted April 13, 2010 Share Posted April 13, 2010 had the same exact problem. u need to get it aligned Link to comment Share on other sites More sharing options...
wpmarky Posted April 13, 2010 Share Posted April 13, 2010 2 options: 1) Alignment 2) Take turns faster! I got -1.1 camber all around with my alignment, but still got outer shoulder wear only, no inner wear =\ Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted April 13, 2010 Author Share Posted April 13, 2010 Thanks everyone. I'm ordering new tires shortly, and will get an alignment and the camber adjusted when I get them installed. Link to comment Share on other sites More sharing options...
Meshanks07 Posted April 14, 2010 Share Posted April 14, 2010 Def just needs an alignment. Link to comment Share on other sites More sharing options...
BrownBoy Posted April 14, 2010 Share Posted April 14, 2010 Make sure you zero out your toe on the alignment. THAT will wear out your tires prematurely and unevenly. Link to comment Share on other sites More sharing options...
