EJ20H-TT Posted January 19, 2004 Share Posted January 19, 2004 It helped that they had just tested an outback with the same engine. So they had a base to work with. Link to comment Share on other sites More sharing options...
PPower Posted January 19, 2004 Share Posted January 19, 2004 They sell the Outback with the 2.0 twinscroll? I thought it only came with a 2.5 NA or the 3.0 H6. Link to comment Share on other sites More sharing options...
EJ20H-TT Posted January 19, 2004 Share Posted January 19, 2004 To clarify It was a 2.5 Legacy they were testing and it's was performance was less than the 2.5 outback they had just tested - so they assumed that something must be wrong with Legacy. Link to comment Share on other sites More sharing options...
SUBE555 Posted January 19, 2004 Share Posted January 19, 2004 Whats the weight difference in your OB 2.5i Wagon to Legacy 2.5i Wagon, same tranny? Kg or Lb. Link to comment Share on other sites More sharing options...
PPower Posted January 19, 2004 Share Posted January 19, 2004 [quote name='SUBE555']Whats the weight difference in your OB 2.5i Wagon to Legacy 2.5i Wagon, same tranny? Kg or Lb.[/quote] [url=http://www.subaru.co.nz/models/outback/technical/specs.pdf]Outback spec pdf[/url] 2.5i 5MT 1430kg 2.5i 4AT 1440kg [url=http://www.subaru.co.nz/models/legacy/technical/specs.pdf]Legacy spec pdf[/url] 2.5i 5MT 1395kg 2.5i 4AT 1405kg Link to comment Share on other sites More sharing options...
EJ20H-TT Posted January 19, 2004 Share Posted January 19, 2004 only 35 kg or 77 pounds Link to comment Share on other sites More sharing options...
SUBE555 Posted January 19, 2004 Share Posted January 19, 2004 If there was a serious difference, guess that shows what a hard break-in can do. Sounds to be more proof I should have even more fun with my car. :D Link to comment Share on other sites More sharing options...
kage Posted January 19, 2004 Share Posted January 19, 2004 The major problem I have with the article is that cars don't come from the factory with zero miles on them. If the first twenty miles are critical, then you're screwed, because those miles happened at the factory before the car ever got on the truck. Cars are run in at the factory for final testing. Their odometers are then zeroed out. Between that and the miles put on at final dealer prep, you're probably looking at ten to fifteen miles already. Link to comment Share on other sites More sharing options...
Dr. Zevil Posted January 19, 2004 Share Posted January 19, 2004 I think the article is hooey. Link to comment Share on other sites More sharing options...
Dr. Zevil Posted January 19, 2004 Share Posted January 19, 2004 Apparently I feel so strongly that I double posted :lol: Link to comment Share on other sites More sharing options...
GBY Posted January 19, 2004 Share Posted January 19, 2004 [quote name='kage']Cars are run in at the factory for final testing. Their odometers are then zeroed out. Between that and the miles put on at final dealer prep, you're probably looking at ten to fifteen miles already.[/quote] Every EJ20T that goes into a WRX is bench tested at the factory before it's dropped into the car. Link to comment Share on other sites More sharing options...
team23jordan Posted January 20, 2004 Share Posted January 20, 2004 yah i wouldn't drive like mofo for first 1000 miles Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
gtguy Posted January 20, 2004 Share Posted January 20, 2004 [quote name='Dr. Zevil']I think the article is hooey.[/quote] I'm with Dr. Z on this one. Both my Legacy GT and WRX wagon were broken in according to Subaru's instructions, and both became hassle-free cars that pulled like fiends. The GT could keep up with RSes, and as regards the WRX wagon, one guy who rode in it with me thought I had some kind of a chip in it. When it was in for routine service, the regional tech rep from Subaru was there, and had it hooked up to a machine. "What's going on," I wondered. "What have you done to this car," he asked. "Nothing," said I. "Why?" He said it was the fastest stock car he'd ever ridden in. :D I'm not changing a thing during the new GT's break in. Kevin Link to comment Share on other sites More sharing options...
legacy2ner Posted January 20, 2004 Author Share Posted January 20, 2004 How did you break it in. Link to comment Share on other sites More sharing options...
PPower Posted January 20, 2004 Share Posted January 20, 2004 "according to Subaru instructions" would be something like nothing over 3000rpm for the first 1000 miles. Basically, drive it gently for the first 1k. Link to comment Share on other sites More sharing options...
gtguy Posted January 20, 2004 Share Posted January 20, 2004 [quote name='legacy2ner']How did you break it in.[/quote] With the GT wagon, nothing past 4K rpm for the first 1,000 miles, and varying speeds. For the WRX wagon, nothing past 4K rpm for the first 1,000 miles. With both cars, I celebrated the end of break-in with a rip-roaring run to redline, though with the WRX I only did this through third gear. Those who have driven a WRX know that redline in fourth is a rather serious number. Kevin Link to comment Share on other sites More sharing options...
legacy2ner Posted January 21, 2004 Author Share Posted January 21, 2004 I wish i could break it in like that but my brother will drive my car and if i tell him to not go past 3k he will because he's an idiot. He drives a WRX so i guess i'll screw around with that if he drives my car (legacy) and i will let him know that i did mess with it. That should not make him drive my car. Link to comment Share on other sites More sharing options...
Dr. Zevil Posted January 21, 2004 Share Posted January 21, 2004 The hardest thing about breakin is the highway miles. Varying RPMS below 3000 on a highway trip is annoying. It would be better if I was able to drive all those miles in the city or country. Link to comment Share on other sites More sharing options...
pengrus Posted July 24, 2006 Share Posted July 24, 2006 Is there a place we can find a dyno? Sounds like Moto Break-in Secret on a Dyno will take less time - only a couple of hours? Link to comment Share on other sites More sharing options...
heybige Posted July 24, 2006 Share Posted July 24, 2006 Damn - for a second I thought we were gonna eminisce about that [URL="http://imdb.com/title/tt0086998/"]great 80's flick.[/URL].. Link to comment Share on other sites More sharing options...
snoman Posted July 24, 2006 Share Posted July 24, 2006 [quote name='heybige']Damn - for a second I thought we were gonna eminisce about that [URL="http://imdb.com/title/tt0086998/"]great 80's flick.[/URL]..[/quote] Bah, you beat me to it. [IMG]http://www.mgm.com/mgm/images/box-dvd/BREAKIN2-box_hires_dvd.jpg[/IMG] Link to comment Share on other sites More sharing options...
