jarod5911 Posted April 11, 2010 Share Posted April 11, 2010 I just bought a set of rims and I am trying to decide on I tire to go with. I want to go the tallest and widest I can without having to roll the fenders. I got a 47 offset wheel that is 8.5 inches wide. I’m thinking about going with at 225/40/18 but I would like to go with a 225/45/18 or a 235/40/18. Has anybody ridden this setup or know which tires will work? Thank you!!! The poll is for which setup would you would go with and be safe with without rolling the fenders thank you!! Link to comment Share on other sites More sharing options...
joeblow Posted April 11, 2010 Share Posted April 11, 2010 Check xenonk's sticky at the top. It will tell you the setups that you're guaranteed not to have rubbing issues and which ones you will have to roll the fenders on. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
DrCloud Posted April 11, 2010 Share Posted April 11, 2010 You realize, of course, what year and specific model you have is a factor in this, right? Are people supposed to guess? HPH Link to comment Share on other sites More sharing options...
jarod5911 Posted April 11, 2010 Author Share Posted April 11, 2010 sorry i edited it and put that in there but i guess it didntshow up i have a 2005 2.5i with stock 16's. i looked at the xenon version but it doesnt have the 225/45/18 size and was just wondering if anybody has ridden this setup and if they had to roll the fenders or not. Link to comment Share on other sites More sharing options...
JonLGT Posted April 11, 2010 Share Posted April 11, 2010 Depends on the ride height. I would do a 235/40/18, but you are going to be close to the fenders. Link to comment Share on other sites More sharing options...
jarod5911 Posted April 11, 2010 Author Share Posted April 11, 2010 Yeah I'm worried an 225 tire will be stretched on a 8.5 inch rim but I want it to fit. Around how much money is it to roll fenders and how difficult is it to roll the fenders? Link to comment Share on other sites More sharing options...
peteyjr Posted April 11, 2010 Share Posted April 11, 2010 I run 225/45/18's but on 7.5 " rims (spec B's) I had minor rubbing issues when I had Swift springs (Very low springs) . No such problems with ION springs which are lower than stock. Most big cities have several shops that roll the fenders . I Looked into it and it cost around 50-75 per fender. Ended up doing a little rolling myself with a heat gun (to prevent the paint from cracking) . Have heard of other DIY 'ers on the NASIOC forums doing it with baseball bats. There is always a risk so its worth it to let a seasoned pro do it. Link to comment Share on other sites More sharing options...
rs6er Posted April 12, 2010 Share Posted April 12, 2010 I have 235/40/18s on 18x 18.5 rims. No rolling necessary. Link to comment Share on other sites More sharing options...
jarod5911 Posted April 12, 2010 Author Share Posted April 12, 2010 I have 235/40/18s on 18x 18.5 rims. No rolling necessary. What was the offset of your rims Link to comment Share on other sites More sharing options...
rs6er Posted April 12, 2010 Share Posted April 12, 2010 +48 Link to comment Share on other sites More sharing options...
peteyjr Posted April 12, 2010 Share Posted April 12, 2010 I have 235/40/18s on 18x 18.5 rims. No rolling necessary. Wow 18.5 " wide, that must be a record on our cars. Link to comment Share on other sites More sharing options...
BigBlack-V Posted April 12, 2010 Share Posted April 12, 2010 I am running 18x8 I believe rims with 245/40/18's and I am rubbing in the rear. I am going to get some spacers for the rears however I wish less wide tires came on the car. I think you should go with 225's that way no rolling will be needed. Mine are rolled btw I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
rs6er Posted April 12, 2010 Share Posted April 12, 2010 Can't use 245/40 without rolling. They are also much larger in circumference than stock. Link to comment Share on other sites More sharing options...
rs6er Posted April 12, 2010 Share Posted April 12, 2010 Wow 18.5 " wide, that must be a record on our cars. They do stick out a bit. I bought the Subaru mud guards to prevent stuff from getting thrown at the sides. I believe 8" is perfect, but the DPTs didn't come in 18x8. Link to comment Share on other sites More sharing options...
coldradio1 Posted April 12, 2010 Share Posted April 12, 2010 I've got 18x8.5 et47 wheels with 225/40 tires. I'm on coils but I'm not too low. The rears are fine. In fact, I almost wish I had some spacers for the rear. The front only rub if I hit a big dip/bump at high speeds. However, I should note, I'm running 0* camber. Probably with 1* or 1.5*, I doubt I would rub. I do plan on giving the front a little roll in the near future. Here's a pic to show my ride height. Also, wheels are Work Emotion 11R. http://farm5.static.flickr.com/4042/4476909879_28e251dd60_o.jpg Link to comment Share on other sites More sharing options...
jarod5911 Posted April 12, 2010 Author Share Posted April 12, 2010 I've got 18x8.5 et47 wheels with 225/40 tires. I'm on coils but I'm not too low. The rears are fine. In fact, I almost wish I had some spacers for the rear. The front only rub if I hit a big dip/bump at high speeds. However, I should note, I'm running 0* camber. Probably with 1* or 1.5*, I doubt I would rub. I do plan on giving the front a little roll in the near future. Here's a pic to show my ride height. Also, wheels are Work Emotion 11R. http://farm5.static.flickr.com/4042/4476909879_28e251dd60_o.jpg Do your tires look stretched over your rims? Or do they fit nicely? Do you wish you went with a 235? Link to comment Share on other sites More sharing options...
coldradio1 Posted April 12, 2010 Share Posted April 12, 2010 There is a slight stretch. And when I mean slight, I mean really slight. I'll take a picture today and post it up tonight. If I had gone 235/40 and gone this ride height, I would have definitely had to roll or even pull the fronts. Link to comment Share on other sites More sharing options...
coldradio1 Posted April 13, 2010 Share Posted April 13, 2010 Here are those pics I promised. http://farm5.static.flickr.com/4021/4517141152_0341c03b25_o.jpg http://farm5.static.flickr.com/4005/4517138730_6a9e8548c2_o.jpg Link to comment Share on other sites More sharing options...
jarod5911 Posted April 14, 2010 Author Share Posted April 14, 2010 Ok I like that look I wish I could do a 235 I proably will next time I get wheels. When u say your running a 0* camber did you do that yourself or did they do that when you got an allighnment? I'm on stock ride height so I should have no problem cleering. Link to comment Share on other sites More sharing options...
coldradio1 Posted April 14, 2010 Share Posted April 14, 2010 Well, I'm on coilovers that have adjustable camber on pillowballs. It was late when I got the coils on and I didn't feel like adjusting the camber so I left it at the 0* that the coils came set on. With stock suspension, you shouldn't have problems fitting this set up at all. Link to comment Share on other sites More sharing options...
jarod5911 Posted April 14, 2010 Author Share Posted April 14, 2010 Well, I'm on coilovers that have adjustable camber on pillowballs. It was late when I got the coils on and I didn't feel like adjusting the camber so I left it at the 0* that the coils came set on. With stock suspension, you shouldn't have problems fitting this set up at all. Ok thanks for all the help Link to comment Share on other sites More sharing options...
wpgspecb Posted May 2, 2010 Share Posted May 2, 2010 I run 225/45/18's but on 7.5 " rims (spec B's) I had minor rubbing issues when I had Swift springs (Very low springs) . No such problems with ION springs which are lower than stock. Most big cities have several shops that roll the fenders . I Looked into it and it cost around 50-75 per fender. Ended up doing a little rolling myself with a heat gun (to prevent the paint from cracking) . Have heard of other DIY 'ers on the NASIOC forums doing it with baseball bats. There is always a risk so its worth it to let a seasoned pro do it. specb is 7" wide Link to comment Share on other sites More sharing options...
wpgspecb Posted May 2, 2010 Share Posted May 2, 2010 I have 235/40/18s on 18x8.5 rims. No rolling necessary. this is with +48 offset? shit i think im gonna return my 18x7.5 at +42 in favour of this size, as Id like to keep the 235/40/18 invos i got. Link to comment Share on other sites More sharing options...
