scottj Posted April 11, 2010 Share Posted April 11, 2010 The Greddy up-pipe I am putting on my MT wagon seems an 1/8 inch shorter than the OEM pipe and that is causing the AVO380 I am trying to install to interfere with the engine case and not sit flat on the up pipe flange. If I double up the gaskets at the top and bottom of the up-pipe the turbo sits flat. Is this going to work? I was thinking about getting the Grimmspeed double thick gaskets but they only make one for the lower flange, not the upper. Is this a common problem? I already moved exhaust manifold and UP around to get the best fit w/o doubling the gaskets and had no luck. Link to comment Share on other sites More sharing options...
m sprank Posted April 11, 2010 Share Posted April 11, 2010 This is not normal. Best bet is to use the GS gasket at the collector/uppipe. Then see where you are at. Double gaskets is a no, no. They are metal layers with an internal ring. Two won't mate properly. Link to comment Share on other sites More sharing options...
scottj Posted April 11, 2010 Author Share Posted April 11, 2010 Maybe I should just get another UP since I don't think a single double gasket will do it. Link to comment Share on other sites More sharing options...
m sprank Posted April 11, 2010 Share Posted April 11, 2010 You woud be amazed at how large and thick the GS gasket is. I think they are larger than 2x. They are 12 friggin layers, lol. They have sealed every uppipe leak I have ever encountered. They are a good 1/8" thick. Link to comment Share on other sites More sharing options...
