turboman38 Posted April 8, 2010 Share Posted April 8, 2010 I had my 05 LGT (manual 5 speed tranny) to the shop yesterday for a "whining" noise. The tech put the car on the rack and determined the noise was coming from the tailshaft housing on the tranny. He said he had done a couple of these where he replaced two gears and a bearing the the tail of the tranny. I replied that he had done that to my car already. I checked with the service manager and they did the job under warrabty at 42,000 miles. I have almost 87,000 on the car now. Is this a normal thing to replace these parts every 40, to 45,000 miles? I don't think it is. They asked me if I was "launching" the car. I admitted that I had done that prior to the first time the did the work but I have not raced the since they did the work the first time. Any idea what would cause these parts to go bad? (gears and bearing in the tail shaft) Link to comment Share on other sites More sharing options...
lgtftw Posted April 17, 2010 Share Posted April 17, 2010 I'm not sure what could cause them to go bad? did you ever get an answer on what it actually was? If it's the center diff I've heard that driving with mismatched tires (one new tire and the others used) or doughnuts can cause it to go bad but I'm not sure if it's true or not. I'm guessing improper alignment or anything that would make the car not symmetrical would cause issues in that section of the tranny. I'm very new to transmissions so I'm not really sure what would cause it but I do want to know what the outcome was. Link to comment Share on other sites More sharing options...
