mightymouse Posted April 5, 2010 Share Posted April 5, 2010 I have an 08 spec b and have noticed that shifting throught the gears is somewhat "clunky" compared the the sti. does anyone know if the I were to swap the subaru short shifter into my legacy if it would make a difference? also would I be able to fit say the mode double adjustable short shifter on top of the subaru short shifter? Link to comment Share on other sites More sharing options...
Bolksey85 Posted April 5, 2010 Share Posted April 5, 2010 Get a Kartboy and save the extra $$$ for linkage and rear stay bushings.;)Most say the STi piece is overpriced for minimal gain. Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 5, 2010 Share Posted April 5, 2010 dont forget to zip tie your reverse cable when you swap out the shifter Link to comment Share on other sites More sharing options...
mightymouse Posted April 5, 2010 Author Share Posted April 5, 2010 do you know if a short shifter would fit on top of the sti piece as well? I'm just trying to get rid of the clunky shifting experience Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 5, 2010 Share Posted April 5, 2010 i dont see why you can't change the shift stick with the factory shift kit with linkage swapped in Link to comment Share on other sites More sharing options...
mightymouse Posted April 5, 2010 Author Share Posted April 5, 2010 i dont see why you can't change the shift stick with the factory shift kit with linkage swapped in do you think this would resemble the smooth shifting action of an sti? or is it the difference between transmissions (6spd spec b. and 6spd sti)? Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 6, 2010 Share Posted April 6, 2010 the tranny is...pretty much the same. i really dont know about the factory shift kit with linkage - i was going to go that route initially but it's 697$ here. so i said screw it. have you tried replacing your tranny fluid? i hear the subaru extra S is the way to go. or you can mix redline 75-90NS with lightweight shockproof Link to comment Share on other sites More sharing options...
mightymouse Posted April 6, 2010 Author Share Posted April 6, 2010 can you not get the sti short shifter online? the dollar is basically at parity.. i figured at most would cost under $400.. I thought the fluid wasn't supposed to be changed really.. how much of an improvement are we looking at in terms of changing fluids? Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 6, 2010 Share Posted April 6, 2010 yeah. after they quoted me that. i found out that i could have bought the sti shifter linkage kit for under 300$USD. dont remember where anymore. you'll eventually need to change the fluid. if you can get your hands on the subaru extra S, i guess i would recommend it - even though i never tried it - . there is a thread about it here. Link to comment Share on other sites More sharing options...
mightymouse Posted April 6, 2010 Author Share Posted April 6, 2010 i'm assuming no one has tried to put a short shifter on the sti short shifter on this forum..i guess i'll be the first..Darkness where are you located in ontario? Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 6, 2010 Share Posted April 6, 2010 scarborough, why? want to meet up? are you also on the toronto subaru club ? - i hate that board. dead for legacy owners/all wrx/sti guys there Link to comment Share on other sites More sharing options...
mightymouse Posted April 7, 2010 Author Share Posted April 7, 2010 eventually...not in canada at the moment... do you know of any meets in toronto? Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 7, 2010 Share Posted April 7, 2010 there's a few weekly. mississauga on thursdays whitby on fridays. there's a bar meet on wednesdays i think on friday there is woodbridge as well..but i'm not sure if that still goes on. Link to comment Share on other sites More sharing options...
mightymouse Posted April 8, 2010 Author Share Posted April 8, 2010 I was reading a post on the sti short shifter linkage unit and it was mentioned that everything was the same between the stock shifter and the SPT STI STS except for the geometry of the shift rod. Is this true? because if it is then adding the the mode or kartboy to the sts linkages wouldn't make that much of a difference. Can anyone confirm this? Link to comment Share on other sites More sharing options...
