aredz Posted April 11, 2010 Author Share Posted April 11, 2010 I ended up putting valvoline 10w-30 high mileage in it. I haven't seen any real change in the knocking yet, but we'll see. I also did another compression test and got great numbers; 170 all around. The more I listen to it, the more i think that it must be something valve related because it does die down a bit when its really warm (c. 30 min). The search continues... Link to comment Share on other sites More sharing options...
FLlegacy Posted April 11, 2010 Share Posted April 11, 2010 You may need to adjust the valve clearance, or it could be a rod knocking. It sounds more like a rod if it is going away as the car warms, valves usually keep making noise no matter the temp of the engine. Link to comment Share on other sites More sharing options...
aredz Posted April 11, 2010 Author Share Posted April 11, 2010 well it quiets down a bit but never goes away for good. I wonder what I might have missed while I was checking the clearances, i'll be honest I'm not very experienced in that area. Maybe i'll see if I can have someone more knowledgeable than myself listen to it. Link to comment Share on other sites More sharing options...
aredz Posted April 13, 2010 Author Share Posted April 13, 2010 So I stopped by the dealer i bought the car from to pick up a couple dash bulbs and had one of the service guys take a quick listen to it. He said the best he could figure it was the ubiquitous boxer engine tick/knock, nothing crazy to worry about. i guess that should put this thread to rest for the time being. The car runs perfectly otherwise so hopefully it will be problem free from here on out. Again, thanks a lot to everyone who offered their .02, I appreciate it. Link to comment Share on other sites More sharing options...
