Connect4 Posted March 30, 2010 Share Posted March 30, 2010 Anyone know how to take the front bumper off? Pics and vids will be awesome if you guys have them. Thank you! Link to comment Share on other sites More sharing options...
brooklyngenius Posted March 30, 2010 Share Posted March 30, 2010 its called search. First you remove the screws where the bumper meets the fender, then remove the grill, then remove all the popits on the bottom of the car and pull. useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
joeblow Posted March 31, 2010 Share Posted March 31, 2010 Remove pop-its underneath. There are 7 or 8 if I recall correctly. There is one inside the wheel well that you'll have to crank the wheel all the way one way or the other and peel the liner back to get to. Remove the pop-its on the grille. The grille can stay on if you want it to. Then you just pull; starting at one corner, by the wheel, works best. There are little clip things that you might have to use a small screw driver to pop loose. then disconnect your fogs if you have them and you're good to go. Then you put it back on in reverse order. Once you've done it once, its not a big deal to do it again. No pics or vids, its been more than a month since I took it off to black out my headlights, and I don't have any other reason to take the bumper off right now. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
