something different Posted March 28, 2010 Share Posted March 28, 2010 i am installing the complete dash from a 06 gt into a 98 leg outback wagon. anyone else done anything this crazy? ideas? how many problems getting it to fit? i have the complete wrecked 06 and a pristene 98 outback, just seemed like something that would be completely unusual! tom Link to comment Share on other sites More sharing options...
MannyMohawk5 Posted March 29, 2010 Share Posted March 29, 2010 good luck, you're looking at a nightmare of re-wiring. Link to comment Share on other sites More sharing options...
something different Posted March 29, 2010 Author Share Posted March 29, 2010 wiring is what i do and i am installing the complete 06 harness in the 98 Link to comment Share on other sites More sharing options...
EyeFlyIsTheEye Posted April 5, 2010 Share Posted April 5, 2010 good luck, you're looking at a nightmare of re-wiring. Not to mention that the dash measurements would be totally different. Swapping a gauge cluster is one thing, an entire dash would be a nightmare. Link to comment Share on other sites More sharing options...
Van Johnson112 Posted April 12, 2010 Share Posted April 12, 2010 go for it, that sounds awesome. Pics if it happens? Link to comment Share on other sites More sharing options...
worknlikeadog Posted April 15, 2010 Share Posted April 15, 2010 I Have been wanting to do the same thing for a long time for my 1996 L. I have to see someone else do this lmk how it turns out. Link to comment Share on other sites More sharing options...
something different Posted April 17, 2010 Author Share Posted April 17, 2010 update, i should have originaly said > i am installing the complete drive train from an 06 GT in a 98 legacy outback wagon. so i thought it would be easier to also install the complete wiring and dash. maybe not........! engine, trans and rear are swapped, fuel pump installed in 98 tank. some sources say the 06 is a CAN data car, others say NOT. so for now i am going with the NOT's and will see what happens. rear swap is easy and 98 axles work with 06 rear. front is another story. must use the 06 axles because of trans (5mt) and different splines in cv joints, so am machining sleeves so the wheel brng grease seals will work with 06 axles. spline in front hub is shorter, but not much so will make special nuts and use permanent locktite. used 06 front subframe with 98 lower arms and 06 rack which has different splines, so will make custom shaft grafted togeather. used 98 alt and a/c compressor with 06 radiator and 98 a/c condenser. also must use 98 shifter on 06 trans, as it is shorter. all in all everything fits, now to sort out how much wiring is needed for ecu to co-operate and cruise to work. i am using the 98 steering column and putting the immobilizer ant and key somewhere behind dash. also have to pick up a speed signal for speedo, will probably put a pickup on one of the front inner c/v joints. i'll post a link to pics later, but it just looks like a subaru! tom Link to comment Share on other sites More sharing options...
