WYO_LGT05 Posted March 25, 2010 Share Posted March 25, 2010 I have an 05 LGT is there anyway to make a stronger rear diff? Mine is busted and subaru has a complete rear diff for a lil over $700. Is there any way to do this cheaper? or is there a stronger rear diff that i can buy for launching? Link to comment Share on other sites More sharing options...
Darkness of Death Posted March 25, 2010 Share Posted March 25, 2010 maybe try rallispec Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted March 25, 2010 Author Share Posted March 25, 2010 Just checked out rallispec. it says... R160 rear LSD case requires modification when fitting with 3.545 and sometimes 3.700 and 3.900 final drives. what is this modification? Link to comment Share on other sites More sharing options...
whitetiger Posted March 26, 2010 Share Posted March 26, 2010 You would want to keep your final drive. it has to match your front diff anyways. if you want a helical rear LSD , then you will just buy the carrier unit and swap you stock ring and pinion on to it. Link to comment Share on other sites More sharing options...
fishbone Posted March 26, 2010 Share Posted March 26, 2010 Opie has a 5EAT, just for reference. WYO_LGT05, I never asked you, in what manner did the rear diff grenade, exactly? You usually hear about center diffs crapping out on the 5EATs as far as I can tell. Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted March 26, 2010 Author Share Posted March 26, 2010 im not sure, it just started one day. im guessing its from launches but not to sure. i was told by another member that had the same issues that it was the rear diff. so im taking it that thats the problem. unless anyone thinks its something else?? Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted March 27, 2010 Author Share Posted March 27, 2010 its still drivable btw Link to comment Share on other sites More sharing options...
whitetiger Posted March 27, 2010 Share Posted March 27, 2010 sounds like you arent sure its busted. tesll us why you think its the diff. what are you experiancing? Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted March 29, 2010 Author Share Posted March 29, 2010 Every time i take a corner while acceleration i hear a repeated poping noise from the rear driver side. also if launching i hear the same noise.http://legacygt.com/forums/../images/smilies/confused.gif this does not happen at higher speeds, only from a beginning roll on turns and launches. Link to comment Share on other sites More sharing options...
fishbone Posted March 29, 2010 Share Posted March 29, 2010 Doesn't sound good, I'd take it easy until you can have someone look at it. I'd hate to hear that the diff grenaded altogether. It could very well be the center differential, or a mount? Have it looked at either way. Easier said than done, it's a laborious project from what I know and rather spendy so I wish you luck and let us know what it turned out being. Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted March 29, 2010 Author Share Posted March 29, 2010 yeah im taking it very easy, i think im just going to fork out some bucks to have subaru inspect it. Link to comment Share on other sites More sharing options...
whitetiger Posted March 29, 2010 Share Posted March 29, 2010 you sure its not the rear end growl thats common on stage 2 cars? it kinda sound like repeated popping from the diff bottoming out the busshings on the case. Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted March 30, 2010 Author Share Posted March 30, 2010 if thats the issue how would i know? i there a walk through on taking the diff apart to check for this? or should i have subi do it for labor costs Link to comment Share on other sites More sharing options...
whitetiger Posted March 31, 2010 Share Posted March 31, 2010 why not have someone give you a second opinion by having them hear the noise first hand. Link to comment Share on other sites More sharing options...
SBT Posted March 31, 2010 Share Posted March 31, 2010 you sure its not the rear end growl thats common on stage 2 cars? it kinda sound like repeated popping from the diff bottoming out the busshings on the case. From the OP's description, that's exactly what I thought. Mine does the same thing. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted April 2, 2010 Author Share Posted April 2, 2010 so if this is a bushing problem, what bushings do you think they could be and where to buy new ones? Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted April 3, 2010 Author Share Posted April 3, 2010 ok so i talked to a relative thats a mechanic and he believes i just need to grease up the cv joints as they get dry sometimes. so im going to purchase a needle oil gun and juice it up and ill let everyone know the outcome Link to comment Share on other sites More sharing options...
SBT Posted April 3, 2010 Share Posted April 3, 2010 ^^ That's not going to do anything for the issue that you're describing. If the CV boots aren't compromised, then the CV joints aren't "dry". - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted April 3, 2010 Author Share Posted April 3, 2010 lol so what the hell is it, it cant be busted diff, changed fluid and no metal or signs of break. bushings maybe but have no knowledge on bushings Link to comment Share on other sites More sharing options...
fishbone Posted April 5, 2010 Share Posted April 5, 2010 Look into this http://www.rallitek.com/whredibu.html I am considering a set myself Here are a couple of threads as reference http://legacygt.com/forums/showthread.php/5eat-clunk-rear-during-gear-100501.html?t=100501 http://legacygt.com/forums/showthread.php/whiteline-rear-diff-bushingsiii-118811.html?t=118811 Link to comment Share on other sites More sharing options...
WYO_LGT05 Posted April 5, 2010 Author Share Posted April 5, 2010 im going to order these and install them and post the aftermath. thanks for the help Link to comment Share on other sites More sharing options...
