SC GT Posted March 16, 2010 Share Posted March 16, 2010 I read JDMChizad's thread about swapping an '07 Spec B interior into an '05 and it sounds like way more trouble than I'm looking for. Does anyone know whether the '06 leather seats (or '05 for that matter) are plug and play into an '05 non-limited? I might have the opportunity for some '06 seats, but first want to know what parts I'll need and what I'd be getting myself into. Thanks. Link to comment Share on other sites More sharing options...
Wuzkrackin83 Posted March 16, 2010 Share Posted March 16, 2010 05 has the passenger seat sensor built into the rails. 06 and up has the bladder. 05 has the passenger seatbelt attached to the seat. 06 and up has it attached to the pillar Link to comment Share on other sites More sharing options...
SC GT Posted March 16, 2010 Author Share Posted March 16, 2010 So '05 leather would be plug and play into an '05 non-limited? Pity about the '06. I was hoping that the "improvements" were made in '07. Link to comment Share on other sites More sharing options...
Wuzkrackin83 Posted March 16, 2010 Share Posted March 16, 2010 can you verify that the seatbelt is attached to the seat and not the pillar on yours ? also take a flash light and look under your seat in the four corners and if you see little motor/box looking things then yes it is Link to comment Share on other sites More sharing options...
Wuzkrackin83 Posted March 16, 2010 Share Posted March 16, 2010 if you dont have heat warmers on your seat then you might have an extra plug on the leather seats. Link to comment Share on other sites More sharing options...
flander Posted March 16, 2010 Share Posted March 16, 2010 can you verify that the seatbelt is attached to the seat and not the pillar on yours ? also take a flash light and look under your seat in the four corners and if you see little motor/box looking things then yes it is I just checked my seat and it is attached to the seat and not the pilar. Link to comment Share on other sites More sharing options...
Wuzkrackin83 Posted March 16, 2010 Share Posted March 16, 2010 then 05 has to be swapped with 05 or else you wont have the right sensor for the passenger detector. Link to comment Share on other sites More sharing options...
danny boy Posted September 4, 2011 Share Posted September 4, 2011 Old thread from the dead! What I'm hoping to do: Motorized leather seats (05 limited) into a non limited 05, which has cloth, non- motorized seats. Is the motor wiring already there, or is it a different harness altogether? Anybody done this? The non- limited has heated seats, airbag sensors, seat belt chime sensors, etc. Not sure what wuzcrackin refers to when he talks about motor/box things under the seat corners- Link to comment Share on other sites More sharing options...
zmarko Posted September 5, 2011 Share Posted September 5, 2011 Old thread from the dead! What I'm hoping to do: Motorized leather seats (05 limited) into a non limited 05, which has cloth, non- motorized seats. Is the motor wiring already there, or is it a different harness altogether? Anybody done this? The non- limited has heated seats, airbag sensors, seat belt chime sensors, etc. Not sure what wuzcrackin refers to when he talks about motor/box things under the seat corners- Unbolt your seat (after removing the negative battery terminal) and tilt it backwards. You'll see all the wiring attached to your seat. Count how many plugs you have. Fish inside the carpet for an extra plug. I'm 99% sure people have done this swap before. The main pain in the ass of swapping seats is the fact that the seatbelt is connected to the seat in the '05, so you either have to remove the anchor point from the seat (which requires a special torx head if I'm not mistaken), or remove the B pillar and remove the entire seat belt assembly. Link to comment Share on other sites More sharing options...
zmarko Posted September 5, 2011 Share Posted September 5, 2011 You can try and use this as something to compare them to (if you can make it out in my pic). http://img.photobucket.com/albums/v319/zmarko/dayfour1.jpg Link to comment Share on other sites More sharing options...
