garylau Posted March 14, 2010 Share Posted March 14, 2010 In right turns from a stop, if I'm even a little heavy on the gas, I get some horrible wheel hop. Keep in mind I'm not burning out or anything, this happens if I'm driving even a little aggressively. Is this common for these cars? What steps can I take to correct the problem without spending alot on suspension upgrades? My car is front wheel drive. I have new tires and excellent alignment, so I know neither of those are the problem. Link to comment Share on other sites More sharing options...
garylau Posted March 17, 2010 Author Share Posted March 17, 2010 Anyone? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted March 17, 2010 Share Posted March 17, 2010 Does it only do this in right turns? If so, it sounds to me like you've got a suspension issue that's causing uneveness in the car. I dunno much about the suspension, but I would think it could be anything from your front right shock/strut needing replacing, to maybe even the left rear, which allows the right front to come up a bit more under acceleration and right hand turns. Def sounds like a suspension issue tho if your tires and alignment are ok. Link to comment Share on other sites More sharing options...
