JimyJoeBob Posted March 12, 2010 Share Posted March 12, 2010 not sure exactly where to put this but I am getting these randomly in my car now. I have a 06 2.5i automatic. ABS light is constantly on and it say ERR SS. Cruise control also doesnt work. They turned on a few days ago and havent gone away. I know it has something to do with a speed sensor and I am going to try reconnecting the battery to see if it will fix it. I read somewhere about checking CEL codes by a built in diagnostic tool. Not sure if my car is equipped with it or not and maybe I could figure out which one to look at. I havent looked yet but understand if I do have it they would be white plugs by the fuse box on the drivers side. Any help is appreciated. Link to comment Share on other sites More sharing options...
schwinn Posted March 12, 2010 Share Posted March 12, 2010 It's not "Err SS" it's ERR 55... this indicates a problem with the wheel sensors (which is why ABS is disabled as well). I would start by checking the wheel sensors for damage to the wires or the shutter wheels. Link to comment Share on other sites More sharing options...
JimyJoeBob Posted March 24, 2010 Author Share Posted March 24, 2010 anyone with info about checking the codes just using plugs in the car and the trip display thing. anybody know if my car is equipped with it? and how exactly to go about it Link to comment Share on other sites More sharing options...
ja_bwoy Posted March 26, 2010 Share Posted March 26, 2010 Found this really cool link to help with the problem http://www.subaru-car.ru/leg4/leg4_chas_8.pdf Also to find the panel check this link http://legacygt.com/forums/showthread.php/code-reader-23292.html?t=23292. My problem is still there but at least now I know where I'm going Link to comment Share on other sites More sharing options...
katalyst Posted March 27, 2010 Share Posted March 27, 2010 It's not "Err SS" it's ERR 55... this indicates a problem with the wheel sensors (which is why ABS is disabled as well). I would start by checking the wheel sensors for damage to the wires or the shutter wheels. it actauly is Err SS standing for the speed sensors, but it displays as 55 on the dash most likely you have a faulty speed sensor somewhere, or did you get stuck in some snow recently? Link to comment Share on other sites More sharing options...
__raj Posted March 27, 2010 Share Posted March 27, 2010 Where you stuck and spinning the tires and it went on? Mine has gone off when I was spinning the tires trying to get my buried LGT off the median (it did!) last winter. It usually goes off after a few drive cycles (on-drive-off). Link to comment Share on other sites More sharing options...
katalyst Posted March 27, 2010 Share Posted March 27, 2010 ^ yeah if it's from gettign beached, it'll clear after about 4 cycles after it re-calibrates itself but otherwise you might have a faulty sensor Link to comment Share on other sites More sharing options...
JimyJoeBob Posted March 28, 2010 Author Share Posted March 28, 2010 i havent gotten stuck or anything, it came on one day when i turned the car on Link to comment Share on other sites More sharing options...
