ErosSalvatore Posted March 7, 2010 Share Posted March 7, 2010 My mechanic told me the clutch is weak because it has a high engagement point....it's almost near the point of being fully realized before it gets into gear....what exactly does this mean? how long will the clutch last? will the clutch last long if i take care of it better....i realized that i was riding the clutch and i assume that this was causing the problem..... Link to comment Share on other sites More sharing options...
sqc151 Posted March 7, 2010 Share Posted March 7, 2010 u can adjust the clutch by adjusting the clutch bolts under the hood. u should have 1 inch of play at the top, clutch should catch in the middle. Link to comment Share on other sites More sharing options...
lionel025 Posted March 8, 2010 Share Posted March 8, 2010 this also might simply be because you are just about out of clutch. Thats what happened before mine went. Link to comment Share on other sites More sharing options...
