Jimmy78 Posted March 2, 2010 Share Posted March 2, 2010 i have a magnaflow cbe currently and jus bought a invida dp do i need adapters or direct fitment? Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 2, 2010 Share Posted March 2, 2010 I would get the adapter. Invidia is 3", magnaflow flange is 2.5" Link to comment Share on other sites More sharing options...
Jimmy78 Posted March 2, 2010 Author Share Posted March 2, 2010 where can i get a adapter like this? Link to comment Share on other sites More sharing options...
Jimmy78 Posted March 2, 2010 Author Share Posted March 2, 2010 and wat size gaskets do i need? Link to comment Share on other sites More sharing options...
Darkness of Death Posted March 2, 2010 Share Posted March 2, 2010 the adapter....try fred beans.. not sure if they would have it but still. they are a popular choice. i believe you'd need both a 3" gasket and the stock donut gasket to get it going. Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 2, 2010 Share Posted March 2, 2010 Fredbeans has the adapter here: http://www.fredbeansparts.com/servlet/the-2651/3-Inch-Downpipe-to/Detail They give you options when you order if you want to include the donut gasket, or include the donut gasket and flat flange gasket. Don't forget to buy a new gasket for the turbo->DP connection either Link to comment Share on other sites More sharing options...
Jimmy78 Posted March 2, 2010 Author Share Posted March 2, 2010 so i need the donut gasket for this install? Link to comment Share on other sites More sharing options...
m sprank Posted March 3, 2010 Share Posted March 3, 2010 Yes. You could probably reuse the OEM, but I don't recommend reusing gaskets. Even asbestos donut gaskets. Link to comment Share on other sites More sharing options...
JohnnyGT08 Posted March 3, 2010 Share Posted March 3, 2010 what invidia DP did you get? If you got the divorced pipe, you should probably grind the divorced section down a bit before you install it. Plenty of pictures on here showing where. Just search for invidia dp rattle....you'll find it. NEVER ARGUE WITH A STUPID PERSON. THEY WILL DRAG YOU DOWN TO THEIR LEVEL, THEN BEAT YOU WITH EXPERIENCE. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
greg_mitch Posted March 7, 2010 Share Posted March 7, 2010 So you have a 3" DP and a 3" CBE but you are going to flange down to 2.5"? Doesn't it make sense to just cut off the old Magnaflow flange and get a 3" flange installed so it is straight through? Sorry if this is a stupid suggestion...I am just learning. Link to comment Share on other sites More sharing options...
m sprank Posted March 7, 2010 Share Posted March 7, 2010 You can. No problem doing this. Many members do. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 7, 2010 Share Posted March 7, 2010 So you have a 3" DP and a 3" CBE but you are going to flange down to 2.5"? Doesn't it make sense to just cut off the old Magnaflow flange and get a 3" flange installed so it is straight through? Sorry if this is a stupid suggestion...I am just learning. Would I rather resell a 3" magnaflow later than live with a 2.5" b-neck now? Yes sir, yes I would. If resale of the magnaflow is an issue, just get a 2.5" flange to go with it if and when:cool: Link to comment Share on other sites More sharing options...
