moneypit Posted February 28, 2010 Share Posted February 28, 2010 any one done head gaskets on 2.2L non turbo them self? do i have to pull motor? i kwow it needs doing cooling system is over pressuizing and blowing coolant out the overflow, while the temp gage redlines. but that olly happens while driving or when rad cap is on. at idle she stays mid range on temp gage even after a 1/2 hour of running. so i figure its exhaust entering coolant system. Thanks in advance Link to comment Share on other sites More sharing options...
garylau Posted February 28, 2010 Share Posted February 28, 2010 I'd find out the problem for sure before you think about replacing the head gasket. I could be wrong, but I think your problem is going to be a little more simple than that. I think your radiator cap might be bad, which would explain the overflow. I'm not sure if that could cause it to run hot, though. Link to comment Share on other sites More sharing options...
Bdubs Posted February 28, 2010 Share Posted February 28, 2010 Yeah replace radiator cap and the thermostat first. Then bleed the cooling system appropriately. Go from there! Link to comment Share on other sites More sharing options...
DN1911 Posted February 28, 2010 Share Posted February 28, 2010 if it is the headgaskets you don't have to pull the engine and you don't even have to pull the intake all the way out. take the engine mount nuts off and jack the engine up and you can wiggle the head out..... lost count of how many time i have done it this way Link to comment Share on other sites More sharing options...
silver03 Posted March 1, 2010 Share Posted March 1, 2010 I had very similiar symptoms in our 93, replace the rad cap first. Same issues, intermittant, but still there. Replaced the tstat with a proper burping...problems gone. Link to comment Share on other sites More sharing options...
moneypit Posted March 18, 2010 Author Share Posted March 18, 2010 hey all, thanks particularly garylau,and Bdubs! the rad cap was bad as the problem is fixed I just didn't think of it as a viable option because of the over-pressurizing of the rad hoses. It makes complete sense now I just got dense and couldn't see the simple first. 600-800 if I did 1500-2000 if Ihad it done so thats alot of thanks Link to comment Share on other sites More sharing options...
moneypit Posted March 18, 2010 Author Share Posted March 18, 2010 sorry fogot thanks also to silver03 spot on on the rad cap. Link to comment Share on other sites More sharing options...
