darkside Posted February 28, 2010 Share Posted February 28, 2010 Hey guys I have Prodrive P1 18x7.5 53mm offset. Buying some BBK for fronts. Does any body know how much of a spacer I should add to clear Brembo or stoptech bbk. I saw these on ebay. http://cgi.ebay.com/ebaymotors/HUBCENTRIC-WHEEL-SPACERS-ADAPTERS-5MM-IMPREZA-WRX-STI_W0QQitemZ170446092099QQcmdZViewItemQQimsxZ20100216?IMSfp=TL100216142005r38618 Will these work. Should I get spacer and longer wheel studs. How hard is it to change wheel studs.. Will the Sti spacers and wheel studs fit on legacy gt. Thanks for feedback:spin: Link to comment Share on other sites More sharing options...
darkside Posted February 28, 2010 Author Share Posted February 28, 2010 Wow 21 views, anybody know its sti studs same as legacy. I know spacers will fit, but studs? Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 28, 2010 Share Posted February 28, 2010 Do a search with 'spacer' in the title of the tread. Lots of opinions and solutions to your questions. No expert here, but I've gathered 04 STi parts will work on your legacy. Make sure it's hubcentric and use something quality (H&R or Eibach). You could likely get away with 5mm spacers and stock bolts, but might not be good for your hubs and bearings (?). Many won't even consider this an option and will simply recommend the correct size rims. Pressing the studs yourself is do-able, but a pain and not too expensive to have done (ie $200 for all four wheels). Please don't quote me, not an expert. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
rnstein69 Posted February 28, 2010 Share Posted February 28, 2010 Wow 21 views, anybody know its sti studs same as legacy. I know spacers will fit, but studs? I was in a similar situation a while back and here is a thread that relates to extended studs. http://legacygt.com/forums/showthread.php?t=108946 Long story short I ended up going with Nismo 60mm extended studs (same thread pitch and knurl as most subarus) and they are 12mm longer than the stock studs (which are 48mm) If you can get a set of 04 STi BBS wheels then they will clear the brembos no problem. My issue was the ASA wheels that I got, the holes are very deep and I would only get 3 turns on each wheel nut where the stock wheels I would get something like 7 or 8 turns. Link to comment Share on other sites More sharing options...
lil_z_33 Posted May 10, 2010 Share Posted May 10, 2010 my volk rims were 49 offset, I needed a 7mm spacer to clear, but hubcentric kits start off at 15mm for H&R, and H&R comes with longer studs...installed them two nights ago, clears brembos no problem, gonna test out stock rims soon to see if they clear as well... Link to comment Share on other sites More sharing options...
