chile Posted February 25, 2010 Share Posted February 25, 2010 the tech says mine is broken...didn't say if it was physically broken or messed up from swapping to a cone filter vice the stock air box with a drop in filter. if it's the latter, is it gone or can i reinstall the stock set up and it correct the readings it's getting? don't know if i worded that right....thanks. Link to comment Share on other sites More sharing options...
Spec B Posted February 25, 2010 Share Posted February 25, 2010 It's a MAF sensor and you should clean it before you replace it. Intake should not make a difference. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 25, 2010 Share Posted February 25, 2010 I'm assuming you've already made sure everything is plugged in and no wires were damaged? I would put the stock airbox on and reset the ECU first before doing anything else since it's the least invasive. If that doesn't work, try cleaning it next. Link to comment Share on other sites More sharing options...
chile Posted February 26, 2010 Author Share Posted February 26, 2010 Yeah the subie tech here called it air flow meter/sensor...everything is plugged in. I will put in a new filter when I put the stock box back on...thx Link to comment Share on other sites More sharing options...
