stealitall Posted February 25, 2010 Share Posted February 25, 2010 Whats a better set up Large front / Small rear - Small Front / Large rear - or Even front and back???? Just a Reg old setup all I need.. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 25, 2010 Share Posted February 25, 2010 Better for what? Personally, I'd go with an adjustable large front/small rear. Do a search if you want more details on what the effects of swaybar sizing. Link to comment Share on other sites More sharing options...
AZP Installs Posted February 25, 2010 Share Posted February 25, 2010 All cars are setup to push from the factory because it's safer than a spinning car. So you want to increase the rear to give you more rotation. I usually upgrade both to larger size or get adjustable front and rear and dial it in to my liking. -mike Link to comment Share on other sites More sharing options...
papa g Posted February 25, 2010 Share Posted February 25, 2010 I am going with larger adjustable on both. Front one comes in next week. Already have the 25 on the back and it feels so much better than stock. BE committed to DO what it takes to HAVE more of what you want in your life!!! Link to comment Share on other sites More sharing options...
subiedad51 Posted February 25, 2010 Share Posted February 25, 2010 I put a 22mm perrin adj on the rear and it makes a ton of difference even with the stock on the front. I'll be upgrading my suspension shortly but even with the sway it's a worthwhile upgrade. Link to comment Share on other sites More sharing options...
AZP Installs Posted February 25, 2010 Share Posted February 25, 2010 Yup sways make a nice difference. I have the whiteline adjustables on my car. -mike Link to comment Share on other sites More sharing options...
SubyShop.com Posted February 26, 2010 Share Posted February 26, 2010 Considering the rear bar is a 16mm noodle... I like a slightly larger front bar for my driving style. (23 F, 21 R) -Franz Link to comment Share on other sites More sharing options...
GTTuner Posted February 26, 2010 Share Posted February 26, 2010 Perrin 22's frt and rear, both set to firm. The car will push at first but will go neutral once I play with the throttle. If I use heavy throttle I can feel the rear really stick, it works nicely. I can "steer" my car with the throttle. Jam on the brakes mid turn and the tail gets loose but never looses traction. Link to comment Share on other sites More sharing options...
BrooklynBoy Posted February 26, 2010 Share Posted February 26, 2010 Perrin 22's frt and rear, both set to firm. The car will push at first but will go neutral once I play with the throttle. If I use heavy throttle I can feel the rear really stick, it works nicely. I can "steer" my car with the throttle. Jam on the brakes mid turn and the tail gets loose but never looses traction. GT......please 'splain to this suspension noob what "push" means. I'm confuuuzed. . I never considered that an upgraded set of sways could alter the direction of your travel ! I just assumed that thicker bars would give you a car that is less prone to body roll.....(You learn so much reading everything in this forum !) Eventually I will be upgrading my sways for my DD spec B.......now I need to research the effects of larger rear , or larger front or vice versa. Do it right the first time.........or don't bother doing it at all. Link to comment Share on other sites More sharing options...
captainhook Posted February 26, 2010 Share Posted February 26, 2010 I run Perrin 22mm bars front and rear, front stiff, rear soft and like it quite a bit for daily driving. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 26, 2010 Share Posted February 26, 2010 GT......please 'splain to this suspension noob what "push" means. Push = understeer. In really simple terms, it's when the car keeps going straight when you're trying to turn because the front end lost traction. Link to comment Share on other sites More sharing options...
