heresmymind Posted February 20, 2010 Share Posted February 20, 2010 Time has come where I am going to turbo my legacy gt. I do not have thousands to spend on a swap due to being a fulltime student, but from having many friends in the subaru community I have been able to source lots of OEM turbo parts. So I will be doing a custom Turbo set up. Keep in mind my engine only has 30,000 miles on it! it runs like a top and still gets 25mpg city 29 highway! It will consist of : TD04 set at 7psi (debating ewg)WRX TMIC w/ loudest RFL valve I can find haha. (woo inner ricer)custom uppipe retaining my borla headers (no need for turbo cross member)custom downpipe with HFCstainless oil lines taped from oil galley, return to oil pan.RRFPRSTI fuel pump EM either pp6 or Megasquirt stand alone , Tune by EFI -B Teaser Pic http://i50.tinypic.com/2djnf53.jpg engine bay before the craziness begins! http://i46.tinypic.com/yhtth.jpg Link to comment Share on other sites More sharing options...
amp27 Posted February 20, 2010 Share Posted February 20, 2010 dude. turboing these motors and like driving on rivers in November. i would never do it without building up the motor for the extra power. i know its only 7psi but still. Link to comment Share on other sites More sharing options...
heresmymind Posted February 20, 2010 Author Share Posted February 20, 2010 i have friends with 2.5 rs-t's they turbod safely, its all in the tune. my engine is practically new with arp studs/commetic gasket. so i'll be fine for low boost -B Link to comment Share on other sites More sharing options...
amp27 Posted February 20, 2010 Share Posted February 20, 2010 ok ok sounds like you know what your doing more then me. Link to comment Share on other sites More sharing options...
oregonemilio Posted February 20, 2010 Share Posted February 20, 2010 You should post a walk through... Im planning on doing the same to mine and it would be helpful to see the process Link to comment Share on other sites More sharing options...
GNG_Kirby Posted February 20, 2010 Share Posted February 20, 2010 You should post a walk through... Im planning on doing the same to mine and it would be helpful to see the process Agreed Link to comment Share on other sites More sharing options...
WESTcoast Posted February 21, 2010 Share Posted February 21, 2010 can i has your cold air intake then plzzz kthxbai Link to comment Share on other sites More sharing options...
gathermewool Posted February 21, 2010 Share Posted February 21, 2010 You're smart in getting a good tune, but high(er) compression motors don't need to detonate to wipe a bearing. Good luck with the build. I'm curious to see how it turns out! '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
Matt Murray Posted February 21, 2010 Share Posted February 21, 2010 What are you going to do with the tubing that goes to the air filter? If you are going to sell it let me know.. Matt Link to comment Share on other sites More sharing options...
amp27 Posted February 22, 2010 Share Posted February 22, 2010 how is this going???update? Link to comment Share on other sites More sharing options...
