blue2.5gt Posted February 19, 2010 Share Posted February 19, 2010 Just wanted to start by saying thanks for the help you have given me with my car so far. I own a 2005 legacy gt 5eat. I have 2 10" subs in a ported box in the trunk of my car. It sounds really good, but as most of you know sometimes you get the feared buzzing that comes from the rear deck area. I went to the audio shop that installed the sub and after banging on a few things to check for vibrations he said it was most likely all coming from that plastic box that has the housing for the center rear seat belt. Apparently theres a spring in there that makes a hell of a lot of noise. Since all my friends and I are in college, no one can ever fit in the middle seat in the back so its never even be used. I was wondering if its hard to take out that middle seat belt, and if it would have any effect on the safety systems the car comes with (for sure dont want to mess with that). The guy also mentioned that he could dynamat the whole rear deck but it sounds like that might cost a couple hundred bucks. So before I shell out any cash I was wondering if anyone has had the same issue with the vibrating, and if they found the seatbelt holster was the culprit. If so, can it be removed easily and safely? Or should I just go with the dynamat? Thanks, blue2.5gt Link to comment Share on other sites More sharing options...
lil_z_33 Posted February 19, 2010 Share Posted February 19, 2010 more than likely your third brake light doing the vibration against the rear window... Link to comment Share on other sites More sharing options...
FJuan Posted February 19, 2010 Share Posted February 19, 2010 To answer your question about the mid rear seat belt removal is not that hard. 1. Remove the bottom seat (pops out)2. Remove the back seat. (2 bolts on bottom)3. Pop the rear deck up far enough to unbolt the seat belt housing. (1 bolt)4. Unbolt the seat belt on the bottom. (1 bolt) There's no sensors running to the rear seat belts, so it shouldn't cause any problems. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
blue2.5gt Posted February 20, 2010 Author Share Posted February 20, 2010 more than likely your third brake light doing the vibration against the rear window... ya that makes sense too, would dynamating the rear deck stop that vibration though? also thanks for the instructions on how to remove the seat belt, ill ask the guy at the shop if he will do it Link to comment Share on other sites More sharing options...
FJuan Posted February 20, 2010 Share Posted February 20, 2010 Maybe or maybe not, it all depends on where the noise is coming from. You'll need to pinpoint exactly where it's coming from, or otherwise you might waste your money on dynamting. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
lucas569 Posted February 20, 2010 Share Posted February 20, 2010 dl this focal test and set up cd, start at track 12 and maybe all the way to track 20, and track the rattle. add dynamat as needed. No need to pay someone when you can do it yourself. http://www.megaupload.com/?d=2NG7BY73 Focal Disk Two – Tools 1. Left and Right Channel Test2. Pink Noise Reference -14B Fs3. Front Channels Polarity Test4. Subwoofer Tracks - Single Cylinder Motorcycle Engine5. Subwoofer Tracks – Muffled6. Subwoofer Tracks – Soured7. Subwoofer Tracks – Walking Cello8. Digital Silence 0 Bits9. Sine Wave Reference 1kHz 14dB Fs10. Sine Wave 20Hz11. Sine Wave 25Hz12. Sine Wave 31 Hz13. Sine Wave 40 Hz14. Sine Wave 50 Hz15. Sine Wave 63 Hz16. Sine Wave 80 Hz17. Sine Wave 100 Hz18. Sine Wave 125 Hz19. Sine Wave 160 Hz20. Sine Wave 200 Hz21. Sine Wave 250 Hz22. Sine Wave 325 Hz23. Sine Wave 400 Hz24. Sine Wave 500 Hz 25. Sine Wave 630 Hz26. Sine Wave 800 Hz27. Sine Wave 1kHz28. Sine Wave 1.2kHz29. Sine Wave 1.6kHz30. Sine Wave 2kHz31. Sine Wave 2.5kHz32. Sine Wave 3.15kHz33. Sine Wave 4kHz34. Sine Wave 5kHz35. Sine Wave 6.3kHz36. Sine Wave 8kHz37. Sine Wave 10kHz38. Sine Wave 12kHz39. Sine Wave 16kHz40. Sine Wave 20kHz41. 20 Hz to 160 Hz42. 160 Hz to 1.25kHz43. 1.25kHz to 10kHz44. 10kHz to 20kHz45. Walking Saxophone – Left – CTR – Right – CTR46. Pencil Drawing47. Tape Roller Unrolling48. Bulb Drop49. Jug50. Oboe51. Cello52. Acoustic Guitar53. Drums – Progressively rise in Intensity54. Drums – Toms55. Base Line Drums56. Bass Play57. Bass Slap58. Applause59. Applause Outdoor60. Oliver Lataste – Le phare et la lune61. Male Voice – Pierre Delorme – Reves62. Female Voice – Chislain Marchetto – L’homme de la dernier63. Male & Child Voices – Gilles Pauget – Blues d’automne64. Vocal Group – J.Joplin arranged by E. Moulin65. Jazz Rock – arranged by R.Guillard – Over the Rainbow66. Jazz – RMR – Maja67. Doumka Clarinet Ensemble & Youval Micenmaker68. 109 – Donne69. Romain Gayral – Solminharm (High spectral density setting drivers response test)70. Compressed Drums71. Uncompressed Drums72. Compressed Oliver Lataste – La derniere borne73. Uncompressed Oliver Lataste – La derniere borne74. Compressed Orchestra75. Uncompressed Orchestra Link to comment Share on other sites More sharing options...
blue2.5gt Posted February 20, 2010 Author Share Posted February 20, 2010 hmm, well the sub was originally set to below 75Hz as the crossover frequency. Should I still test the frequencies above that? and is there any member in the hartford, ct area that may be willing to spend a couple hours and help a fellow legacy gt owner out in the process of doing this =) (preferabely if they have done it on their own car) ? because as ive been reading once the dynamat goes on it does not want to come off, and since ive never done it before id really like to learn how to do it the right way. Thanks for the help! blue2.5gt Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted February 22, 2010 Share Posted February 22, 2010 Yeah I would definatly try to narrow it down more. It may be that belt holder (pretty sure I have this too, along with the third brake light on the window which is easily fixed with foam tape), but if its a part inside that holder and you sound deaden over and around it, all it will do is trap it there and it will still rattle...lol. just play any music that you can hear it rattling to and crawl around in the trunk and back seat. have some foam adhesive backed tape, or 3/8 by 5/8 weatherstripping handy and some scissors. When somthing you touch stops rattling wedge a piece of whatever you have in beside it. Rattle hunting made easy. Link to comment Share on other sites More sharing options...
blue2.5gt Posted March 8, 2010 Author Share Posted March 8, 2010 more than likely your third brake light doing the vibration against the rear window... i think your right, i went rattle hunting and this seems to be causing the majority of the rattle. What exactly should I do in this area to stop the vibration? Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted March 9, 2010 Share Posted March 9, 2010 Small piece of foam weather strip in between the glass and the plastic housing. Link to comment Share on other sites More sharing options...
blue2.5gt Posted March 10, 2010 Author Share Posted March 10, 2010 Small piece of foam weather strip in between the glass and the plastic housing. this seems to have helped some, thanks. do you have a trunk system in your car? Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted March 11, 2010 Share Posted March 11, 2010 http://www.legacygt.com/forums/showthread.php?t=117587&highlight=custom Yes Link to comment Share on other sites More sharing options...
