And I'm done
Mr. Ed
with power mods that is....
*No correction factors used on this Dyno
Event: Dyno Tuning
Ambient Temp: 40 deg
Elevation: 600 Ft
Weather: sunny, cool
2008 WRX
Tuner: Kieth Fields@AWDtuning.com
Dyno Info: Mustang 1100
Peak HP at RPM: 363@5044rpm
Peak Torque at RPM: 419@4240rpm
Baseline : Will have from AWDtuning by end of day
Target Boost: 22 psi
Target AFR: Will have from AWDtuning by end of day
Fuel: E85
Engine/Power Modifications: Kamak TD05 18g 8cm , XO2 FMIC, Custom 3" TBE, TGV deletes, Walbaro Fuel Pump, Modded stock Injectors (900ish cc), wrapped APS EL Header
Driveline Modifications: Spec stg 3 clutch, stock flywheel
Suspension Modifications: rallitek springs and sways, stock
Other Modifications: fn01rc wheels 18x8.5
http://i69.photobucket.com/albums/i51/maryfields/MrEdsGraph2-16-10a.jpg
http://farm5.static.flickr.com/4016/4283674317_96ba717907_b.jpg
