quick4dr Posted February 17, 2010 Share Posted February 17, 2010 got 63,500 miles on car. I want to do a front diff drain and fill. how many quarts of diff oil do I need what is the best to go with? I did the rear diff with royal purple 75w90, and tranny with BG fluid, just got front diff left to do. Link to comment Share on other sites More sharing options...
doctorbrody Posted February 17, 2010 Share Posted February 17, 2010 Fluid capacity is 1.3 qts, and start checking the dipstick after you put in 1.1. I use Subaru's Extra S fluid, but I hear good things about Amsoil Severe Gear 75W-90 too. Also, you need a Torx 70 bit to open the plug, which you can get on eBay for 5 or 6 bucks. Link to comment Share on other sites More sharing options...
quick4dr Posted February 17, 2010 Author Share Posted February 17, 2010 got the bit already, does subaru sell the extra s fluid by the quart, i recall reading that it only came in gallon size? Link to comment Share on other sites More sharing options...
doctorbrody Posted February 18, 2010 Share Posted February 18, 2010 Fred Beans sells it by the quart. Link to comment Share on other sites More sharing options...
quick4dr Posted February 19, 2010 Author Share Posted February 19, 2010 awesome, thanks for the info. any other recommendations? tips... Link to comment Share on other sites More sharing options...
fishbone Posted February 19, 2010 Share Posted February 19, 2010 BG is not on the list of ATF that meets SOA's specs. I would think twice about using it but subscribing for your results. The only ATF we know of that is not SOA-approved and works great is Amsoil. The rest are anyone's guess.Don't worry about the Extra S stuff, that is aimed at the MT guys since it affects their shifting. Go with the same diff fluid you used for the rear. Extra S won't make a lick of difference. Link to comment Share on other sites More sharing options...
quick4dr Posted February 20, 2010 Author Share Posted February 20, 2010 so, use the royal purple stuff in the front diff? and re- drain and fill my tranny? havnt had any issues, but i dont mind draining it again, its real easy. Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted February 22, 2010 Share Posted February 22, 2010 A lot of people, myself included, use Red Line 75w90. Just another option for you. Like fish said, its not a MT, so it probably makes little difference. Link to comment Share on other sites More sharing options...
doctorbrody Posted February 22, 2010 Share Posted February 22, 2010 Whatever you use in your transmission, make sure it's all the same stuff. A drain and fill only changes about 4-5 quarts, which is around half capacity. I had IPT flush my 5EAT with Amsoil Universal ATF when they installed my valve body, and now I just do an Amsoil drain and fill every 15-20k. I'm sure the Royal Purple 75W-90 is fine for your front diff. Link to comment Share on other sites More sharing options...
fishbone Posted February 22, 2010 Share Posted February 22, 2010 Any good quality 75w90 will do the trick. Don't go terribly out of your way for some magic elixir, I would just get whatever is easy to get at a reasonable price. Personally I went with Amsoil severe gear because I was able to get it locally for cheaper than off the shelf other synthetic lubricants. M1 makes some good 75w90, so does Pennzoil and Valvoline. Link to comment Share on other sites More sharing options...
car_cursed Posted April 28, 2012 Share Posted April 28, 2012 Okay, I feel like an idiot, and seeing as how i'm not physically in front of the car at the moment. But to fill the front diff with fluid it fills through the transmission dipstick tube? or is there are seperate dipstick tube for the fron diff? If so where is it located? Edit: I think I have figured it out, the trans dipstick is on the drivers side, and the diff is on the passenger, please correct me if I am wrong Link to comment Share on other sites More sharing options...
scoobyscoodle Posted April 29, 2012 Share Posted April 29, 2012 Yes, you fill the front diff through the front diff dipstick on the passenger side. Link to comment Share on other sites More sharing options...
