meier motor sports Posted April 5, 2005 Share Posted April 5, 2005 in my manual trans gt i found a good launch technique. i rev it to about 3k. u dont wana be holding it there so if possible let the clutch out as im about to tell u just as its revin up to 3k. so anywaysrev it to about 3k and slowly but swiftly let the clutch out. dont dump it let it slip a bit. but not to much. and jsut as u start goin mash the gas all the way down and all the way off the clutch. this feals like a pretty good launch to me. my glove box had fallen open on the last try and on this try the owners manual shot out of the glove box and landed on the seat. and that owners manual fits pretty snugly inside the hole. i find that dumping the clutch gives u a slight chirp and then the car bogs and then takes offthe way i am telling i once got a tiny bit of squeel from the left front i belive and the car took off Link to comment Share on other sites More sharing options...
melayout Posted April 5, 2005 Share Posted April 5, 2005 It's much more fun and much less destructive in mud or snow. I keed I keeed Link to comment Share on other sites More sharing options...
ChruiSSer Posted April 5, 2005 Share Posted April 5, 2005 I found blipping the throttle around 4k and then slipping the clutch as I floored it to be the best method. The only problem is you don't want to slip it too much, but you don't want to bog it either. Link to comment Share on other sites More sharing options...
meier motor sports Posted April 5, 2005 Author Share Posted April 5, 2005 I found blipping the throttle around 4k and then slipping the clutch as I floored it to be the best method. The only problem is you don't want to slip it too much, but you don't want to bog it either. yeah on one try i sliped it real bad:eek: if there was day light i think there would have been a mushrrom cloud behind me. or something Link to comment Share on other sites More sharing options...
ChruiSSer Posted April 5, 2005 Share Posted April 5, 2005 I had the same thing. Except I was blipping it at around 5k and slipped it. Halfway into the launch the rpms shot up to 6k and the clutch pedal went to the floor although I wasn't pressing on it...wtf? Then it TOOK off. I think there was too much power though and it was the *clutch* slipping. Now I won't go above 4k. For the rest of that night all I smelled was clutch... Link to comment Share on other sites More sharing options...
