dombek2k7 Posted February 13, 2010 Share Posted February 13, 2010 Ive posted previously bout this, i got 1 respons with a link to follow. Have a friend working on my car as we speak and i followed the directions/link (http://www.legacygt.org/forums/showthread.php?t=1678&goto=newpost) so this picture/direction doesnt match up to my 05lgt. theres no blue an white striped wire (thats what my buddy said) please help!! Link to comment Share on other sites More sharing options...
Windy Road Posted February 13, 2010 Share Posted February 13, 2010 I believe on the 05-06 all you have to do is pull the DRL white connector out and thats it. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
ssabat Posted February 13, 2010 Share Posted February 13, 2010 Noob! Link to comment Share on other sites More sharing options...
SneakyFast Posted February 13, 2010 Share Posted February 13, 2010 It's a five step process but it's pretty easy! Step 1: Click here: http://legacygt.com/forums/search.phpStep 2: Type the words "DRL disable" into the keywords boxStep 3 (optional): Select "Search titles only" from drop down under keyword boxStep 4: Click the search buttonStep 5: Read Link to comment Share on other sites More sharing options...
Ssej Posted February 13, 2010 Share Posted February 13, 2010 I believe on the 05-06 all you have to do is pull the DRL white connector out and thats it. Correct. There is a plug for the DRL unit under the dashboard, to the door-side of the clutch pedal. Unplug that, stick it somewhere it won't rattle around, and you are good. Link to comment Share on other sites More sharing options...
