rustler753 Posted April 4, 2005 Share Posted April 4, 2005 Okay, final desision time. All the wheels are a possiblility. All use the correct bolt pattern and I think have a reasonable offset. Here they are: 18"x7.5" with a 48mm offset are the wheels with the black spokes 18x8 with a 38 mm offset. is for the Wrx look-a-likes and 18x7.5 with a 42 mm offset for the alloy wheels with the chrome spokes Just which would look best on a 05 legacy gt limited with rear spoiler. The bids will end soon so please reply asap. Link to comment Share on other sites More sharing options...
Xenonk Posted April 4, 2005 Share Posted April 4, 2005 the 18x8 with 38 offset wont work, period. It will stick out of the fender by almost 1/4", if not, more once you have a big wide tire on there. You are better off getting those 7.5" wide wheels. Keefe Keefe Link to comment Share on other sites More sharing options...
Legasee Posted April 4, 2005 Share Posted April 4, 2005 What color is your Legacy? I've learned to be on the safe side and go with proper specs cuz the wrong specs can give you problems such as rubbing (most likely if you do decide to lower your car) and other issues. Don't sacrafice safety for looks and good luck bidding! (I'm about to do it myself) In Taiwan now... Link to comment Share on other sites More sharing options...
rustler753 Posted April 4, 2005 Author Share Posted April 4, 2005 What color is your Legacy? I've learned to be on the safe side and go with proper specs cuz the wrong specs can give you problems such as rubbing (most likely if you do decide to lower your car) and other issues. Don't sacrafice safety for looks and good luck bidding! (I'm about to do it myself) My car is metallic red and also so that the 18X8's are out then, so which one now, the black spokes or the "shiny" spokes. Link to comment Share on other sites More sharing options...
ChE Outback XT Posted April 4, 2005 Share Posted April 4, 2005 Black Spokes get my vote. Link to comment Share on other sites More sharing options...
