longfoto Posted February 5, 2010 Share Posted February 5, 2010 I've got a 96 Legacy GT with some ongoing electrical issues. One of which is the fact that my 3rd brake light on the spoiler, almost appears to be non-functioning. Upon further inspection in a dark garage, I can see it is lighting up but very very very faint. Before I go replacing it, how can I tell if it's the light, or related to an overall electrical issue with the car? I'm also noticing the instrument gauges are very faint at idle, but get brighter as I accelerate (same with all interior lights in general). I'm noticing the same thing with the headlights. Could it be a short someplace, and how to I check for such a thing? My mechanic says it's not the alternator. So hmmmm.... where to start. Link to comment Share on other sites More sharing options...
subikid90 Posted February 6, 2010 Share Posted February 6, 2010 Sounds like a ground issue. Take the brake light out and test the positive wire to a good ground source and see how bright the tester light is. This is a good place to start. You can do it for your headlights also. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
