Jordan Posted February 5, 2010 Share Posted February 5, 2010 I have had an IAG uppipe for about 6 months now and after a few months the O2/Heat sensor keeps poping out. I have had a tech at my work screw it back in several times. sometimes with loctite this time with teflon tape. I know the thing is goint to pop out agian so short of welding it in what are my options? I know the Iag pipe might not be the most common but it seems like the threads arent the right size cause it is a consisent problem nomader how tight its screwed in. Thanks. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted February 5, 2010 Share Posted February 5, 2010 maybe there is some kind of machining error in the threads of your current bung? one option is to remove the UP and then take out the sensor. screw in an O2 plug and tack weld it to keep it from coming out. Then install another O2 bung (obviously it needs to be welded in) and put the sensor there. On the search for a new DD... Link to comment Share on other sites More sharing options...
mwiener2 Posted February 5, 2010 Share Posted February 5, 2010 go to a different mechanic. If he tried to use loctite or teflon tape on something that gets over 1000 degrees F... you can put some high temp exhaust repair epoxy on the threads... just a lil, it'll hold it in place and still be able to break it loose if need be. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Jordan Posted February 5, 2010 Author Share Posted February 5, 2010 Great thanks for the advice. Link to comment Share on other sites More sharing options...
jackfortune Posted September 28, 2010 Share Posted September 28, 2010 The recommended anti-seize for the sensor is SS-30 Jet Lube, a copper based product NOT TEFLON OR LOCTITE.... Link to comment Share on other sites More sharing options...
mwiener2 Posted September 28, 2010 Share Posted September 28, 2010 actually, you shouldn't need anything on it My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
jackfortune Posted September 29, 2010 Share Posted September 29, 2010 If you want a good installation use SS-30 Jet Lube. For an example using the OEM front oxygen sensor installed in the passenger side exhaust manifold, go to page FU(H4DOTC)-35 of the service manual for this engine...threads on sensors need anti-seize....and the recommended anti-seize for this specific application (sensor in very hot location) is the copper based SS-30 Jet Lube....available through Amazon if you can't get it locally in small quantities... Link to comment Share on other sites More sharing options...
