slickfast Posted February 3, 2010 Share Posted February 3, 2010 Hey guys, I'm looking to install some pretty serious Hella 700FF auxiliary lights with 100W bulbs, and I'm looking for a good place to install them. They will be used only in the rally I'm getting ready for, so no worries about them being strictly road legal. I want to attach them to the bumper in front of the grill, which requires getting the bumper cover off so I can bolt some brackets directly to whatever metal is under there. However, I have NO idea how to disassemble the front end of these cars, and I'm not about to go buy a Haynes manual just for the job. In short, how do I take off the bumper cover? Thanks a lot guys, Colin Link to comment Share on other sites More sharing options...
wrxya33 Posted February 3, 2010 Share Posted February 3, 2010 First off you need to take your headlights and grill off. On top there are like 10 plastic clips. On the fenders there is one screw on each side. Under the bumper there is another 8-10 plastic clips and then in the bumper opening on the top there are about 4-5 more plastic clips. Its rather easy and i have gotten mine off in about 10 minutes. Hope this helps. Link to comment Share on other sites More sharing options...
slickfast Posted February 4, 2010 Author Share Posted February 4, 2010 yeah i saw those clips, but they seem like they're one-way clips. How do you get them off without breaking em? Link to comment Share on other sites More sharing options...
legacygt33 Posted February 4, 2010 Share Posted February 4, 2010 If i remember correctly the middle of them prys up letting you pull them out. But no matter what your giong to break a few they are old and fragile. Its more of a pain then diffacult. If yo have 2 piece headlights with one piece being the sidemarker and one being the headlight assembly there are 4 bolts holding your headlight and one screw holding the corner light. @ on top of the headlight and one behind the grill and another behind the corner light. Incase i didnt specify earlier. Well good luck and if you ahve more questions ill try to help. Also since you have a 2nd gen legacy you should go on SLI.com its much better for our cars and may even have a walk through taking off the bumper for jdm foglights or something. Ill take a lok and post a link if i find something. Link to comment Share on other sites More sharing options...
wrxya33 Posted February 4, 2010 Share Posted February 4, 2010 Here ya go pics and info on removing the front bumper good luck. http://www.sl-i.net/FORUM/viewtopic.php?f=39&t=2766 Link to comment Share on other sites More sharing options...
rmb2485 Posted February 5, 2010 Share Posted February 5, 2010 Just use some self tapping screws. They should grab pretty well in the plastic bumper. Link to comment Share on other sites More sharing options...
one bad bg Posted February 5, 2010 Share Posted February 5, 2010 ^ ya that. i used short screws for mine and never had a problem. mine were cheap auto zone fogs but as for mounting, fogs are fogs. http://legacygt.com/forums/picture.php?albumid=310&pictureid=1770 http://legacygt.com/forums/picture.php?albumid=310&pictureid=1620 Link to comment Share on other sites More sharing options...
httrdd Posted February 5, 2010 Share Posted February 5, 2010 Just use some self tapping screws. They should grab pretty well in the plastic bumper. Never use just screws to mount anything! Drill it then use nut and bolt. Much more secure! Link to comment Share on other sites More sharing options...
slickfast Posted February 5, 2010 Author Share Posted February 5, 2010 There's the gold. Thanks for the link, that will definitely help me get where I need to go. Well done! To everyone else throwing uneducated guesses at mounting serious auxiliary lights that must withstand the abuse of rallying: just... please stop. That wasn't my question, and "fogs are fogs" couldn't be less true. I'll just save you further embarrassment and leave it at that. Link to comment Share on other sites More sharing options...
wrxya33 Posted February 5, 2010 Share Posted February 5, 2010 There's the gold. Thanks for the link, that will definitely help me get where I need to go. Well done! To everyone else throwing uneducated guesses at mounting serious auxiliary lights that must withstand the abuse of rallying: just... please stop. That wasn't my question, and "fogs are fogs" couldn't be less true. I'll just save you further embarrassment and leave it at that. No problem hope everything goes well. Link to comment Share on other sites More sharing options...
one bad bg Posted February 5, 2010 Share Posted February 5, 2010 that must withstand the abuse of rallying i rally'd...often.. and never had an issue. Link to comment Share on other sites More sharing options...
slickfast Posted February 5, 2010 Author Share Posted February 5, 2010 I think our definition of "issues" is a little different. Also, you said you were using cheap little autozone lights. These are larger and heavier. Screwing 6.5 inch glass-lense driving lights is a recipe for wobble, eventually leading to them falling off. Link to comment Share on other sites More sharing options...
one bad bg Posted February 5, 2010 Share Posted February 5, 2010 eh probably true. my 6.5 inch fogs that i replaced the stock ones with i did actually drill, nut, and bolt it. Link to comment Share on other sites More sharing options...
