sportwagon Posted February 3, 2010 Share Posted February 3, 2010 So yesterday on the way into work I had a serious problem (at least it felt like one)... I was accelerating in 5th up an incline and when I hit about 1.1 - 1.2 barr, the car violently jolted and stuttered... I immediatley let of the gas and due to work priorities I wasn't able to pull over and check out the car... I did hook up the AP and switched to economy mode and did a quick data log of the issue... which was happening at a much lower boost level ~ 8 psi by the time I was able to get a log... Anyway, I left the car at work and I am driving my wife's car... Attached is the log I took. I have an 05 LGT sedan MT, with 99,000 miles Stage 2 with Cobb Stage 2 maps... I'll post up a full mods list if needed. I've never done any tuning (only a tuning/data logging noob, not a full noob), but I did notice that there was no wastegate duty going on? I'll attach another log I took a while back to give a reference of when things were working fine and dandy? Can any of the gurus identify anything wrong from the limited data logging info provided? Please help! Thanks, sportwagon02Feb10 data log - problem at boost.csvHighway home from Thanksgiving 2009.csv Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 3, 2010 Share Posted February 3, 2010 You probably hit fuel cut because of overboost. Is your DP catted or non-catted? Cobb specifically says that you must use a catted one when using their map. Link to comment Share on other sites More sharing options...
sportwagon Posted February 3, 2010 Author Share Posted February 3, 2010 catted dp... would a fuel cut feel so violent? Link to comment Share on other sites More sharing options...
lookslikeanevo Posted February 3, 2010 Share Posted February 3, 2010 check for boost leaks Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
sportwagon Posted February 3, 2010 Author Share Posted February 3, 2010 will do... Link to comment Share on other sites More sharing options...
Spec B Posted February 3, 2010 Share Posted February 3, 2010 catted dp... would a fuel cut feel so violent? when I first hit boost cut, it felt to me as if I blew the engine...it is pretty violent; immediately afterwards I got a CEL and I was limited to 8-9 psi. I thought Boost cut always leads to CEL tho. EDIT. Just read your whole post..when limited to 8-9psi, there was no stuttering or hesitation. Link to comment Share on other sites More sharing options...
ultimakf7 Posted February 3, 2010 Share Posted February 3, 2010 check for boost leaks +1 Boost leaks would do it. Link to comment Share on other sites More sharing options...
mwiener2 Posted February 3, 2010 Share Posted February 3, 2010 No WDC is because you are running the eco map My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
sportwagon Posted February 4, 2010 Author Share Posted February 4, 2010 No WDC is because you are running the eco map That's what I thought might be the case! So a boost leak might be the problem.... I was thinking more serious based on how it felt... I haven't driven the car, it's parked in the parking garage at my work, I got a ride home last night and drove my wife's car into work today! I'll check the usual suspects for boost leaks tomorrow! Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 4, 2010 Share Posted February 4, 2010 I don't think a boost leak would have caused the problem. If anything, a boost leak would lead you to seeing less boost and the car would just run like crap. I still think you overboosted from going up an incline in 5th. Link to comment Share on other sites More sharing options...
ultimakf7 Posted February 4, 2010 Share Posted February 4, 2010 I don't think a boost leak would have caused the problem. If anything, a boost leak would lead you to seeing less boost and the car would just run like crap. I still think you overboosted from going up an incline in 5th. A leak in the air line to the wastegate actuator would cause the turbo to overboost. Link to comment Share on other sites More sharing options...
sportwagon Posted February 4, 2010 Author Share Posted February 4, 2010 I don't think a boost leak would have caused the problem. If anything, a boost leak would lead you to seeing less boost and the car would just run like crap. I still think you overboosted from going up an incline in 5th. What would be the consequences of an overboost? Link to comment Share on other sites More sharing options...
mwiener2 Posted February 4, 2010 Share Posted February 4, 2010 Worst case: Pop goes the engine My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ScoobyLife Posted February 4, 2010 Share Posted February 4, 2010 I always start by pulling the intercooler off and checking all the boost lines. Link to comment Share on other sites More sharing options...
mwiener2 Posted February 4, 2010 Share Posted February 4, 2010 I'd ignore it unless you can make it happen repeatedly My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 4, 2010 Share Posted February 4, 2010 A leak in the air line to the wastegate actuator would cause the turbo to overboost. Good point, I hadn't though of that. A leak in the line would be unusual though. The hose usually pops off before anything else. Link to comment Share on other sites More sharing options...
sportwagon Posted February 6, 2010 Author Share Posted February 6, 2010 There wasn't (or isn't) just a leak... the large hose that runs to the IC split!!! I need a new hose ASAP Link to comment Share on other sites More sharing options...
mwiener2 Posted February 6, 2010 Share Posted February 6, 2010 duct tape My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
