WTBmoreboost Posted February 3, 2010 Share Posted February 3, 2010 Okay , bought an amp and subs , went to bestbuy got all my wiring , this wont be my first install so im not a total nub , but my problem is i was planning on using the adapter ( might be a hi/low adapter ) that splices into the speaker wire for the Rcas . well the problem is the speakers arent in the rear deck ( trunk ) theyre in the doors , does anyone know where i can hook into them without tearing the doors apart , and if i have to take the door panels off how do i do so without ruining them , also whats a good spot for the remote wire , somewhere on here i read if you remove the driverside inner fender lining theres a removable grommet thats perfect for running boost gauge lines , audio cables etc , any pics of this , HELP ME ? plz Link to comment Share on other sites More sharing options...
m sprank Posted February 3, 2010 Share Posted February 3, 2010 I tapped in behind the headunit. Way easier than the doors. Link to comment Share on other sites More sharing options...
str8dwn Posted February 3, 2010 Share Posted February 3, 2010 Use a forward and reverse harness from SVXdc to tap into the factory speaker wiring without cutting the OEM harness. Link to comment Share on other sites More sharing options...
WTBmoreboost Posted February 4, 2010 Author Share Posted February 4, 2010 i used to have a 92 svx , loved it , anywho uhh i tapped in beside the passenger seat for the rca cables ( adapter ) , for the remote i cut into the center console power outlet , everything else was easy mode . Read one post somewhere on here as to a good spot for running stuff over the inner fender ( splash guard ) which i loved , shoved my boost/vacuum line through there same time i did my power wire , gonna post pics in a minute have to upload the ones of the boost gauge Link to comment Share on other sites More sharing options...
WTBmoreboost Posted February 4, 2010 Author Share Posted February 4, 2010 oh took all the crap back to bestbuy ( amp wiring ) and went to my buddies local shop and saved 80 dollars , on the same parts , no discount or anything full price , made me feel better . Link to comment Share on other sites More sharing options...
FJuan Posted February 4, 2010 Share Posted February 4, 2010 1st pull the radio out. 3 bolts on each side. http://im1.shutterfly.com/media/47b7d731b3127ccec240be78f84f00000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ Here are the wires behind it. http://im1.shutterfly.com/media/47b7d731b3127ccec2419e09595200000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ Close up http://im1.shutterfly.com/media/47b7d731b3127ccec240409079e800000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ In-line converters attached. http://im1.shutterfly.com/media/47b7d731b3127ccec2417c6fd87500000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ RCA attached to converters. http://im1.shutterfly.com/media/47b7d731b3127ccec24034ea79a800000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ I have a wiring diagram, but it's for the '05 model, not sure it's the same for the '07 models. Let me know if you want it. Good luck. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
FJuan Posted February 4, 2010 Share Posted February 4, 2010 This is what I did to wire my amp. Battery to the fender well. http://im1.shutterfly.com/media/47b7d731b3127ccec24027f8b81b00000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ Pull the wheel well cover back. http://im1.shutterfly.com/media/47b7d731b3127ccec241e587984900000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ Red wire going into the small grommet. http://im1.shutterfly.com/media/47b7d731b3127ccec2405ca679d000000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ My amp is place under the drivers seat. http://im1.shutterfly.com/media/47b7d731b3127ccec241496619ce00000010O00AZtHDZo1bt2IPbz4S/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/ My wife's balls are delicious. Link to comment Share on other sites More sharing options...
WTBmoreboost Posted February 4, 2010 Author Share Posted February 4, 2010 i got it all done TY bunches , good photos , didnt want to pull out HU since its what everyone first sees ( didnt want any scratches ) , thinking about doing the Nav-Video mod next ( grounding ebrake wire , installing dvd player to video in ) . I ran my power wire between the battery and fuse box through that hole in the engine bay , then over the splash guard just as you did , then made a small hole in the HUG grommet with the main harness on it , and my amp is in the trunk on the box , will have pics up tomorrow Link to comment Share on other sites More sharing options...
FJuan Posted February 4, 2010 Share Posted February 4, 2010 Cool. Looking forward to seeing your pics, as I'm building a sub box this weekend. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
WTBmoreboost Posted February 4, 2010 Author Share Posted February 4, 2010 just waiting on the mail from my phone Link to comment Share on other sites More sharing options...
