samron333 Posted February 1, 2010 Share Posted February 1, 2010 Hello, new to the forum with a 98 Legacy GT, the stock stereo is making a horrible static noise when adjusting the volume and I want to take the system out of my truck and put it in this car. I have been trying to find a wiring diagram for the stock unit so I can install the connector for my aftermarket unit. I have had no luck so far, does anyone know where I can find one? Link to comment Share on other sites More sharing options...
SVXdc Posted February 1, 2010 Share Posted February 1, 2010 Legacy/Outback radio harness pin-out Some contact cleaner spray into the volume knob shaft might cure the problem. If you do pull the stock radio, I'd be interested to see clear pictures of the front, back, and label on the top. Link to comment Share on other sites More sharing options...
samron333 Posted February 1, 2010 Author Share Posted February 1, 2010 Thanks for the link. I am going to pull the stock system regardless of the volume issue due to my aftermarket system being newer with more features and it has an ipod adapter built in. I will take some pics for you and post them when I have it pulled. Link to comment Share on other sites More sharing options...
peterd Posted February 4, 2010 Share Posted February 4, 2010 if you want to just make things easy for installing an aftermarket radio I have an extra wiring harness for sale Link to comment Share on other sites More sharing options...
