thunderdan Posted February 1, 2010 Share Posted February 1, 2010 what the difference between a 05WRX TMIC vs 05LGT TMIC?which one flows better?would a wrx tmic fit on an lgt?if u had a wrx tmic laying around would u put it on ur lgt if u are going to stage2+EBCS Link to comment Share on other sites More sharing options...
Bolksey85 Posted February 1, 2010 Share Posted February 1, 2010 1. Fitment2. Don't know, neither is anything special.3. Only with a WRX/STi fitment turbo.4. Only if the $$$ was NOT there for a better TMIC. STi top, maybe. WRX, nah. Link to comment Share on other sites More sharing options...
SBT Posted November 23, 2011 Share Posted November 23, 2011 WRX will require different intake manifold, piping and turbo outlet. WRX may flow marginally better, but neither TMIC is anything special You could not put a WRX TMIC on an 05 LGT (or any 4th Gen LGT) without modification Should be intuitively obvious from these pictures. 2005 WRX TMIC Top Side http://img407.imageshack.us/img407/6595/tmices1.jpg 2005 WRX TMIC Bottom Side http://www.ecotecforum.com/Personal/Sale/tmic.jpg 4th Gen Legacy GT TMIC top http://legacygt.com/forums/attachment.php?attachmentid=78649&d=1262653635 4th Gen Legacy GT TMIC Bottom Side http://legacygt.com/forums/attachment.php?attachmentid=78650&d=1262653635 Notice the significant difference in the inlet and outlet sides. WRX inlet is under the TMIC and the TB outlet is dead-center in the TMIC, while the LGT inlet is from the side and pushes air across to the opposite side where the outlet angles into the offset TB on the LGT. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
