Ransom Posted January 31, 2010 Share Posted January 31, 2010 First I would like to thank everyone for their input on the site. I've been reading the forums for the last month or so before I registered and I just bought my '07 Spec B. Luvin' it by the way! My question is this: Because I don't ever plan to go past Stage 2, should I even bother changing out the uppipe? Since the '07 stock already has a catless uppipe, would the gains really be worth the trouble and money? Currently I plan to take care of the down pipe and the mid will have a high flow cat. Cat back exhaust is already done. Just finished putting in the short throw shifter and that was worth every penny. Just curious about the pros and cons of taking the trouble to do the uppipe on an '07. Opinions? Thoughts? Link to comment Share on other sites More sharing options...
John M Posted January 31, 2010 Share Posted January 31, 2010 There wouldn't be any gains. You'd be replacing a catless up pipe with a catless up pipe. It couldn't possibly accomplish anything. Link to comment Share on other sites More sharing options...
fonts Posted January 31, 2010 Share Posted January 31, 2010 There would be very little benefit if you are planning at stopping at stage 2. Link to comment Share on other sites More sharing options...
Ransom Posted January 31, 2010 Author Share Posted January 31, 2010 Thanks all, good to know. Link to comment Share on other sites More sharing options...
dudeondacouch Posted January 31, 2010 Share Posted January 31, 2010 There would be very little benefit if you are planning at stopping at stage 2. this. it's hard to stop the modding bug once you start though. but if you do plan on doing a turbo swap down the road, you'll have an easier time of changing out the UP then, anyways. I would stick with the stock one as well. Link to comment Share on other sites More sharing options...
jagcars26 Posted January 31, 2010 Share Posted January 31, 2010 stay stock Link to comment Share on other sites More sharing options...
fonts Posted January 31, 2010 Share Posted January 31, 2010 this. it's hard to stop the modding bug once you start though. but if you do plan on doing a turbo swap down the road, you'll have an easier time of changing out the UP then, anyways. I would stick with the stock one as well. I only swapped out my stock UP when I changed my turbo. At that point the extra install was a piece of cake and a better flowing UP for about $140. made sense for better spool only. Link to comment Share on other sites More sharing options...
wpgspecb Posted January 31, 2010 Share Posted January 31, 2010 First I would like to thank everyone for their input on the site. I've been reading the forums for the last month or so before I registered and I just bought my '07 Spec B. Luvin' it by the way! My question is this: Because I don't ever plan to go past Stage 2, should I even bother changing out the uppipe? Since the '07 stock already has a catless uppipe, would the gains really be worth the trouble and money? Currently I plan to take care of the down pipe and the mid will have a high flow cat. Cat back exhaust is already done. Just finished putting in the short throw shifter and that was worth every penny. Just curious about the pros and cons of taking the trouble to do the uppipe on an '07. Opinions? Thoughts? if your stock uppipe has no cat, dont **** with it. Link to comment Share on other sites More sharing options...
fonts Posted January 31, 2010 Share Posted January 31, 2010 if your stock uppipe has no cat, dont **** with it. It's an 07. Stock UP is catless. Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 31, 2010 Share Posted January 31, 2010 +1 to all the above. The only thing that might be of benefit is one with a bung for EGT. Link to comment Share on other sites More sharing options...
Ransom Posted February 1, 2010 Author Share Posted February 1, 2010 this. it's hard to stop the modding bug once you start though. but if you do plan on doing a turbo swap down the road, you'll have an easier time of changing out the UP then, anyways. I would stick with the stock one as well. Yeah I'm sure it will be difficult to stop the bug! I've already got parts on the way for some must-have upgrades. Makes sense about changing it out when/if the turbo is replaced. On the other hand, I'll probably never put on a more powerful turbo on this car or push the factory too hard because I want the engine to take me past 200k. Link to comment Share on other sites More sharing options...
Ransom Posted February 1, 2010 Author Share Posted February 1, 2010 +1 to all the above. The only thing that might be of benefit is one with a bung for EGT. Kinda new to the whole modding thing, so why would I want one with an EGT bung? I was under the impression that the only thing that needed monitoring was the temps for those who have '05-'06 with the cat involved so it doesn't get too hot. Link to comment Share on other sites More sharing options...
m sprank Posted February 1, 2010 Share Posted February 1, 2010 No EGT in your oem uppipe. They went away. I run a Cobb uppipe on my 08 SpecB and an OEM on my 08 5EAT. Only reason I swapped on the SpecB was the weight. Stock is over 7lbs. Cobb is about half that. Link to comment Share on other sites More sharing options...
scoobydoobie Posted February 1, 2010 Share Posted February 1, 2010 No EGT in your oem uppipe. They went away. I run a Cobb uppipe on my 08 SpecB and an OEM on my 08 5EAT. Only reason I swapped on the SpecB was the weight. Stock is over 7lbs. Cobb is about half that. So you shaved 3.5 lbs off? Major weight savings bro!! Link to comment Share on other sites More sharing options...
m sprank Posted February 1, 2010 Share Posted February 1, 2010 Theoretically 7lbs is equivalent to approx. 1 horsepower. So I gained 0.5hp. Take that, lol. Plus think of the unsprung weight advantage I now have. Honestly, it does nothing. But I got it cheap and it says Cobb on it. Link to comment Share on other sites More sharing options...
Ransom Posted February 2, 2010 Author Share Posted February 2, 2010 Thanks again everyone for your input! By this weekend I should have the parts I ordered which include DP, crank pulley, heatshield, and stock instake. Yes, this car had an SPT CAI on it already and mostly it just makes a noise that I don't like as much as some do. If I ever get the hankering to push over 400hp then I suppose I will want it, but for now I think I'll just sell it. I'll list it soon plus the stocker DP if anyone is interested in either of these parts. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 2, 2010 Share Posted February 2, 2010 So you shaved 3.5 lbs off? Major weight savings bro!! Try dropping it on your foot. OP - I just traded out my UP specifically because I had a up-cat in my '05 and for no other reason. I would not have screwed with it if it was catless like yours unless I was installing a new turbo (at which point, why not do an up while you are there). Out of my DP/UP install, the UP is the one I would not want to have to repeat. Link to comment Share on other sites More sharing options...
flipsubie06 Posted July 29, 2011 Share Posted July 29, 2011 quick question: is the stock uppipe on a 2006 LGT catted or catless? Link to comment Share on other sites More sharing options...
Nrw Posted July 29, 2011 Share Posted July 29, 2011 catted Link to comment Share on other sites More sharing options...
fonts Posted July 31, 2011 Share Posted July 31, 2011 catted +1 Catless started in 07 and up. Link to comment Share on other sites More sharing options...
