O-man Posted April 3, 2005 Share Posted April 3, 2005 I own a 97 GTB, completely standard exept for the air filter. Which is now resting in the garage after getting it towed home, I had recently changed the oil and filter but on my latest venture i was changing gear to slow down through an intersection when she died on me. All the lights on the dash were on and would'nt turn over. Once i got her back home i tried turning it over by hand, no luck, then i thought i'd try backwards and it was quite hard at first but atleast it moved, then unpluged the AFM and turned it over by key, Not good Very big rattles. I have a caved in piston from running too much boost, hence the title of this thead. I was getting 17 psi from an engine that normally runs 12-14 psi, and all i had done was changing the air filter. So how does eveyone elses engines cope with big boost? Link to comment Share on other sites More sharing options...
rc0032 Posted April 3, 2005 Share Posted April 3, 2005 How many miles on the car? How many miles at 17? Link to comment Share on other sites More sharing options...
O-man Posted April 3, 2005 Author Share Posted April 3, 2005 Not sure about miles but has 125,000 kilometers probably only 2000 of those at 17. Link to comment Share on other sites More sharing options...
