sc850r Posted January 30, 2010 Share Posted January 30, 2010 My cigarette lighter has come apart (unscrewed itself). I have tried, but not been able to find a link to tell me how to get the radio surround off so I can access the back of the lighter. Help. I need to hook up my radar detector LOL! Link to comment Share on other sites More sharing options...
Bdubs Posted January 30, 2010 Share Posted January 30, 2010 Use this link to get you started. http://legacygt.com/forums/showthread.php?t=26408&highlight=HVAC+bulbs The pics in the first post will help you get to the top screws of the radio bezel. There are, I believe, two more on the bottom. Take the ash tray out, and peak around, you should see them. Link to comment Share on other sites More sharing options...
amp27 Posted January 31, 2010 Share Posted January 31, 2010 yes. that the ash tray out. and feel the top in there. the screws screw up in the radio directions. youll need a short screw driver i know this as i have your very same car and i have had my radio apart 3 times this week. what color you got? Link to comment Share on other sites More sharing options...
sc850r Posted January 31, 2010 Author Share Posted January 31, 2010 With the lighter screwed back together, I cannot get the whole thing past the center console. How do I remove the piece aorund the shifter or loosen the console and slide it back? Link to comment Share on other sites More sharing options...
sc850r Posted February 1, 2010 Author Share Posted February 1, 2010 I ended up just pulling the piece around the shifter off and then snapping out the lager trim piece around the shifter. I then removed the last 4 screws holdng the console in and slid it back. Link to comment Share on other sites More sharing options...
