BarryT82 Posted January 29, 2010 Share Posted January 29, 2010 I've never had to work on an automatic so I have a question. I could have sworn I saw a post saying to check the atf level when it's cold, but I could be wrong. I have a 2005 Legacy GT 5EAT. I replaced the engine and the torque converter came loose causing a little fluid to spill. The dipstick is showing it a little low when cold. It's between the low and full line. Do I need to check it and add fluid when it's hot or cold? Link to comment Share on other sites More sharing options...
Habitual Line Stepper Posted January 29, 2010 Share Posted January 29, 2010 Drive it around for 15mins, then give the dipstick a check. "I for one do not doubt you, dude. Your car is fast and an internet legend." -Gire Link to comment Share on other sites More sharing options...
I 5EAT Turkey Clubs Posted January 29, 2010 Share Posted January 29, 2010 Your manual will tell you you can do both, but that its better to check when warm. Link to comment Share on other sites More sharing options...
Rick Posted January 29, 2010 Share Posted January 29, 2010 Warm the car up and drive it around for about 15min. Stop on a level surface and with the car idling check the fluid level. Link to comment Share on other sites More sharing options...
BarryT82 Posted January 29, 2010 Author Share Posted January 29, 2010 Gotcha. So check it with the car running? Link to comment Share on other sites More sharing options...
Habitual Line Stepper Posted January 30, 2010 Share Posted January 30, 2010 Gotcha. So check it with the car running? yep "I for one do not doubt you, dude. Your car is fast and an internet legend." -Gire Link to comment Share on other sites More sharing options...
fishbone Posted February 1, 2010 Share Posted February 1, 2010 Make sure it's in Neutral, not Park.As long as the ATF is above the Low or Min marks, but NOT above the Full/Max marks, you are fine. Overfilling the ATF is not a good thing, it'll start splashing and foaming. No bueno. Link to comment Share on other sites More sharing options...
Rick Posted February 1, 2010 Share Posted February 1, 2010 Make sure it's in Neutral, not Park. As long as the ATF is above the Low or Min marks, but NOT above the Full/Max marks, you are fine. Overfilling the ATF is not a good thing, it'll start splashing and foaming. No bueno. Why neutral? According to the vacation pics your supposed to park the car on a level surface and run the gear selector through Park, Neutral, Reverse, Drive, back to Park, and then check the ATF. Link to comment Share on other sites More sharing options...
jhig Posted February 1, 2010 Share Posted February 1, 2010 Only check in park, checking in neutral will give you a false reading. Link to comment Share on other sites More sharing options...
fishbone Posted February 1, 2010 Share Posted February 1, 2010 Good catch, it was supposed to be the other way around. I checked with the repair manual and yes, you do check it while in Park. Run the selector through all the positions first. Link to comment Share on other sites More sharing options...
