TSiWRX Posted May 21, 2010 Share Posted May 21, 2010 ^ Very cool! I believe that's the same kind of stuff that fills the "heads" of active LASER jammers, also aimed to help seal out moisture. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Bolksey85 Posted May 22, 2010 Share Posted May 22, 2010 Any pics of the assemblies without them being on? I'm curious to see how the projectors look in the daylight. Also, do you clear them when you tear them down? If so, that's a good 2 birds/1 stone kinda thing. Link to comment Share on other sites More sharing options...
kojack84 Posted May 22, 2010 Author Share Posted May 22, 2010 Any pics of the assemblies without them being on? I'm curious to see how the projectors look in the daylight. Also, do you clear them when you tear them down? If so, that's a good 2 birds/1 stone kinda thing. They look exactly the same as stock. The only part that is visible is the lens....and a lens looks like a lens. Clearing/painting is obviously easily done once they are apart. I did not do mine, but may eventually. Link to comment Share on other sites More sharing options...
starbai Posted May 22, 2010 Share Posted May 22, 2010 Thanks everyone! Sure. There's a small opening in the cutoff shield, below the cutoff that allows some reflected light to pass through it and thus show up above the cutoff. FWIW, I filled in my cutoff shield which is why there is no light above the cutoff. What did you use to cover of the squirrel finders...and do you think it is possible to cover them up without opening the headlights? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 23, 2010 Share Posted May 23, 2010 It is possible to do without opening them but with how easy it is to open and close them its much, much, MUCH easier to just open them, clear them (if you want) and close them up. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
starbai Posted May 24, 2010 Share Posted May 24, 2010 If I open them up....ill be forced to do another Retro.... Link to comment Share on other sites More sharing options...
kojack84 Posted May 24, 2010 Author Share Posted May 24, 2010 What did you use to cover of the squirrel finders...and do you think it is possible to cover them up without opening the headlights? I used JB Weld, and as was said, it's so much easier to just open the headlights up than to struggle to try and cover that hole through the opening. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 24, 2010 Share Posted May 24, 2010 I use Quiksteel which you can buy at autozone, kragen, etc... OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
