hard downshift
Andreu
well let an unexperienced friend drive my car not thinking he would beat the shit out of my clutch and did one of those from third to second downshifts to speed up. cruising around 3k in 3rd and instead of easing into 2nd he rips it up into gear as hes speeding up. Is there any kind of damage that could of been don here?
Why would he need to double clutch?
I wouldn't worry about it. If he didn't grenade your tranny(if its not broken right now), then all other damage will show later down the road. And when it does show, it'll be questionable whether it was from you, normal wear or your friend.
There are always two camps when this comes up. Those that say you don't need to because your synchros will do it for you (which is true) and those that say do it to reduce wear on your synchros (also true). I go with the latter.
