snoboy Posted January 22, 2010 Share Posted January 22, 2010 My Legacy has developed a new problem. When I stop after a trip, short or long, the interior quickly smells of burnt oil but disappears after a few minutes. A haze also appears inside...which sometimes clings to my clothes giving me that smokey fresh scent!.I checked the firewall as best I could and think I have all seals tight, could it be coming in through the vents??...there is a bunch of oil deposits around the base of the engine...but how is it getting inside the car???Thanks for any ideas... (a few hours later....) I turned off the heat before stopping and this seemed to help...but im looking for a more long term solution. Problem number 2...I took off the hose that goes from the turbo to the throttle body....its inside is lined with oil and the inside of the Throttle body is also caked with oil deposits as well as the air lines that are all interconnected with the intake system, it still runs pretty good considering but, im sure this cant be doing any good...some advice would be greatly appreciated. Link to comment Share on other sites More sharing options...
subikid90 Posted January 24, 2010 Share Posted January 24, 2010 the smell is from oil hitting the cat and burning. This is a common problem with our cars -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
ehsnils Posted January 24, 2010 Share Posted January 24, 2010 Check the inner boot on the left side drive axle at the gearbox. Link to comment Share on other sites More sharing options...
skibob6 Posted January 24, 2010 Share Posted January 24, 2010 Smoke definately came from some fluids burning on the cat, i have a leaking passenger side axle seal. long story short, shit rolls down-hill so it all ends up burning off the exhaust. check under the car, it should be pretty obvious where its coming from. If not clean off all the crud from your engine and put a large piece of cardboard under your car overnight; if there is a leak this should help to identify where its coming from. Link to comment Share on other sites More sharing options...
tbssubaru Posted January 24, 2010 Share Posted January 24, 2010 had the smell problem with my car, it was the passenger side inner cv boot , they tear all the time because of the proximity to the exhaust Link to comment Share on other sites More sharing options...
gathermewool Posted January 28, 2010 Share Posted January 28, 2010 had the smell problem with my car, it was the passenger side inner cv boot , they tear all the time because of the proximity to the exhaust +1 Replaced mine a couple months ago. '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
snoboy Posted January 29, 2010 Author Share Posted January 29, 2010 Hey thanks for the replies...you all pretty much got it right about the smoke. As for the oil in the T.B intake line from the turbo...I was assured it was normal by a subaru mechanic. Link to comment Share on other sites More sharing options...
