Licksnake Posted January 20, 2010 Share Posted January 20, 2010 I have a Subaru Legacy Outback 3.0R sedan (2005). Recently, the engine after warming up will begin to sputter when I come to a complete stop at a light. When I accelerate the sputter goes away. The sputter only occurs when the car is in drive with the brake on. The engine sputter also never occurs when i first start it, it only begins when it has fully warmed up. The engine light hasn't come on yet and this has been going on for over a week. any ideas on what is causing the problem? Please HELP!! Link to comment Share on other sites More sharing options...
max_bobby Posted January 20, 2010 Share Posted January 20, 2010 Did this occur when it was really cold? Link to comment Share on other sites More sharing options...
Licksnake Posted January 20, 2010 Author Share Posted January 20, 2010 Yes, it first started when it was -20 out. but now it is 30-40 degrees out and it is just getting worse. Link to comment Share on other sites More sharing options...
max_bobby Posted January 21, 2010 Share Posted January 21, 2010 I had a similar issue, in my case it was the intake manifold gaskets. It could be a bunch of things, but try the gaskets. Good luck. Just hit me with a pm if you have questions about the cost or work. I also had my PCV valve changed, which can also cause some interesting issues in the winter time. There is a recall going on in Canada, but I didn't get because my car is a US vehicle. Link to comment Share on other sites More sharing options...
Licksnake Posted January 22, 2010 Author Share Posted January 22, 2010 Thanks Max for the input. I just got it back. apparently it was a cylinder misfire. luckily its a small fix and a cheap one at that. Link to comment Share on other sites More sharing options...
